Smarty S-o6 fuel mileage setting
Old Jun 8, 2008 | 10:16 PM
TheOutlaw's Avatar
Post Smarty S-o6 fuel mileage setting
I just got a smarty and was wondering a good setting for fuel mileage.. I curently also have a TST and was wondering a good setting stacked.. For those people that are running the smarty or a the stacked combo TST/Smarty please chime in...Thanks
__________________________________________________ ___________
05 Dodge
current mods: Smarty S-06, TST, HTT 62-12, AFE Stage 2, Exhaust, Built Trans, Fast lift pump
Old Jun 9, 2008 | 06:54 PM
TheOutlaw's Avatar
no one knows ...
Old Jun 9, 2008 | 07:48 PM
HIGHGEAR's Avatar
If you have the REVO and not the TNT, try SW#3,TM#2,TIMING#4,RP#2,WASTEGATE OFF. So far this is the best for me. 688.5 miles on 1 tank of fuel.
Old Jun 9, 2008 | 07:54 PM
shineboy2's Avatar
I can't even imagine numbers like that. I got 18 MPH last tank and thought I did well...
Old Jun 9, 2008 | 07:56 PM
HarleyHauler's Avatar
I have the Smarty S06 -- but what is the REVO? Am I missing something here?
Old Jun 9, 2008 | 08:00 PM
HIGHGEAR's Avatar
Let me note I never went over 65 mph. Took a trip from Baltimore to Buckcannon, WV. Drove on I-70 west to I-68 west to I-79 south which has there share of little mountains on it. I'm sure you know where I-68 and I-79 are, not that far from you shineboy2.
Old Jun 9, 2008 | 08:02 PM
HIGHGEAR's Avatar
Its there latest software that came out I think last month.
Old Jun 9, 2008 | 08:12 PM
Yeah, just went the MADS site and saw it. I will have to install it and play a little. Without a modified tranny I can't go too far anyway, but maybe I can squeak a little more MPGs out of the beast...
Old Jun 10, 2008 | 01:04 PM
shortbed rv's Avatar
Does lower RP and TQ help with milage?
When using 4.11 on sw3 I picked up a 1/2 mpg while towing over stock and a 1 mpg over Quad XZT on level 3.
With revo on sw3 or 5 I have too much smoke. Marco said fuel quality was the problem with the jr smoking. So the question is if one drops the timing back from 4 to 2 to reduce smoke will you lose milage.
It you sure be nice if someone could give us some direction.
Old Jun 10, 2008 | 01:42 PM
BIGDAN65's Avatar
i tried the sw3 timing 4 and mine smoked like crazy could it be because i have bigger turbo?
Old Jun 10, 2008 | 02:52 PM
dodgezilla04's Avatar
the tq man, is what makes the throttle more touchy, lower tq man will give less smoke, and make the instant fueling almost go away. so mileage should improve from that.
the higher timing you can run, the better the economy will be, less of the generated heat will go out the exhaust valves, and your cylinder pressure will be higher, giving you more power per amount of fuel burned.
Old Jun 10, 2008 | 02:56 PM
HIGHGEAR's Avatar
As far as RP, it seems that some get better and some get worse with fuel mileage. I'm still experimenting, but so far I get better fuel mileage with added RP. With TM I'm also still experimenting, but so far the lower the better. It seems like TM#2 gives better fuel mileage then TM#3. But, I'm not towing anything either.
Old Jun 10, 2008 | 04:54 PM
dieselengineer's Avatar
With towing 16,000# 5th wheel, found TM-2, timing on 2, and RP-1 being a good setting. The EGT are under 1000*, in fact I am over the mountain before they peak over 1000*. A little smoke, learned to try to lite peddle until the boost is above 10psi on start out. after 10psi, peddle goes down
Old Jun 11, 2008 | 06:44 PM
I lowered Torque management to default and you are right less smoke.
Old Jun 12, 2008 | 01:00 AM
Jason_K's Avatar
am i hurting anything running timing 3 w/ stock sticks? i know mads site says that timing 3 is for huge injectors but the truck seem to run pretty good on that setting.
