Smarty Problem?...Bob, Marco?
one thing that I think is funny is how these guys always say "IF it was the smarty"......
With the new unit we'll know for sure IF the problem was caused by us. Until then everything is an "IF". In the digital electronics field everything IS or IS NOT. Assumptions have no place in it. Thus "IF" until there's a proof, otherwise it's an assumption. I don't need assumptions I need facts! Everything else is just bla bla bla...
Clear as mud?
Marco
you should stop by and meet all the college station folks you see on here. some local guys have gotten smoke tickets actually....and i've only gotten the finger once for smoke. generally everyone here is cool with smoke....back home i had people following me chewing me out for black smoke...the cops back don't care though since they also drive modded cummins!
And thanks marco for answerin my ? Marco/Bob, I just wanted to know since I think quad once said that one of the DL's used to change the overhead to read a higher # on the MPG meter and it just struck me as odd.
march 2..someone will be around for sure....theres plenty of DTR guys in this town.
Ok, I got the new Smarty. And cleared my codes with it. Then loaded my stock program back in from my old Smarty. Then Downloaded level 5 with the new one, then back to stock. Hvac controls still don't work. Not sure if I am still going to get the other codes. Bob is going to talk to Marco some more. It seems to me that at one time or the other when I was loading the stock program in. It got corrupted. And now I am just downloading a bad stock program in and out of the truck. I dont know though. Maybe we will get this worked out.
I am not sure if this has any Bering on your problem.. My 05.. Once in a while I will start the truck and the HVAC and power windows do not work.. Shut the truck off and restart and all work fine. I am just waiting for this to start happening on a regular basis to take it in to the dealer..
BTW.. no downloaders or boxes have ever been on the truck.. Maybe we have the same thing your has just progressed???
Bob, I couldn't download any stock software out of the new Smaty you sent me. When I plugged it in, it thought the truck was stock. Could only download Catcher settings. Is there anyway for you to email me a stock program than I can download into the Smarty?
Thanks for all your Help, Brad
Bob, Marco just to let yall know. I downloaded another program off the internet. Still the same problems. After I loaded the new program, I was setting in the driveway with the truck running. Started playing with the Hvac controls then while I was doing that. Everything dropped to 0, got all the ABS, Brake, check engine lights. And "no bus" where the mileage should be. Again I am not blaming the Smarty, but it sure does seem like the problem is linked.
sounds more like a "DODGE" problem then a smarty problem, dodge has major electrical issues they need too work out!!! I mean, i cant plug my truck into a gfi recepticle, infact since new it will trip gfi's, but regular outlets are fine.....too bad building codes call for all outside recepticles too be gfi!!
I'm going out on a limb here but it appears that the HVAC control module is acting up. The PCI bus is getting corrupted for some reason and since all other devices are on the same bus it's tripping errors.
From what I have gather it's only doing it when you make changes to the HVAC.
I would try reseating the HVAC connection on back of the unit before doing anything else.
MikeyB
MikeyB
blcoonrod,
Having the first Smarty set an internal failure code... it was a little far fatched but it could have been ( don't know how! ) that your problem was caused by that Smarty. Now that you have a new unit and the problem still remains it's obvious that Smarty's programming has nothing to do with it.
It's not that you can't get rid of a corrupted SW! Again, chances that Smarty could download a corrupted SW into an ECM are close to zero. Maybe even less than that...Let's assume anyway that had happend with the defective unit. The new unit you received would have erased that SW and written a correct one into the ECM. Your ECM HAS a correct SW in it now. For SURE!
I think MikeyB hits the nail on it's head.
Marco
Marco
The " PCI " bus used to connect all the various electronic modules in the truck is a single wire bus. Short just one wire to ground and what you get is a very dead bus. Thus all the light's you see.
To me it sounds very reasonable to assume that the HVAC module causes the problem on the bus. Since you say : "Started playing with the Hvac controls then while I was doing that. Everything dropped to 0, got all the ABS, Brake, check engine lights"......
Makes sense?
Marco
blcoonrod,
Marco
Marco
Shane
