Smarty Jr. and boost fooling?
I have a quadzilla BoostFooler on my truck. I installed it before I got the Smarty.
Does The Jr. do boost fooling?
Would I get any negative affects if I took the Boost fooler off and just ran the Jr.?
ran a quad fooler with the jr. i didnt know the jr did boost fooling it does... i get her up to around 35-36 psi. with the quad i could roll coal alittl more and she would spool alittle quicker thats about it. take the truck alittle longer to hit the mid 30s without the quad bf...
I'm not sure don't have a boost gauge (on the list of wants), I never had a problem setting a code with the original jr software, It started with beta 2 but would only set it with acceleration from OD lockup downshifting to 3rd pulling a trailer. Beta 3 would set it empty on moderately hard acceleration. Not sure about beta 4 I've had the boost fooler on before beta 4 came out.
Are you sure about that 44psi number? I had read it was 32psi and then it would set a cel. Maybe my truck has a bad map sensor or something, it smoked hard core when I had the original jr software on it.
