SMARTY Help Needed!!
Old Jun 4, 2009 | 07:59 AM
DogRam's Avatar
I went to set truck to "stock" with SMARTY (V4.14 R1.15) today and when the SMARTY got to 61%-97% (tried a few times) it aborted the program 'error #42" and left the truck in that state. NO START with the fuel pump going on and off.
I installed FASS afew months ago. Never changed the truck from SW5 before or after the FASS install. This is the first time I have tried to reprogram.
The recovery proceedure gives the same code
Please HELP!!
Old Jun 4, 2009 | 08:12 AM
wyododge06's Avatar
Try pulling the fuel pump fuses and the abs fuses this happened to my buddies truck when he tried to upload my Smarty onto his 05 with a FASS.
Old Jun 4, 2009 | 08:16 AM
DogRam's Avatar
Pull for a few minutes or while I program with the Smarty?
BTW, THanks
Old Jun 4, 2009 | 08:19 AM
DogRam's Avatar
I forget what abs stands for.
Old Jun 4, 2009 | 08:23 AM
TX_Diesel's Avatar
it stands for Anti-Lock Brake System....
Old Jun 4, 2009 | 08:25 AM
wyododge06's Avatar
Pull them and then upload the Smarty while they are out. ABS stands for anti lock braking system.
Old Jun 4, 2009 | 09:19 AM
DogRam's Avatar
Removing ABS & FASS fuses while programming did not help.
Thanks though. Any other suggestions?
Old Jun 4, 2009 | 11:28 AM
MikeyB's Avatar
Going out on a limb here but hook up a battery charger and try again.
MikeyB
Old Jun 4, 2009 | 01:55 PM
ib516's Avatar
Call the guys at MADS/SMARTY or maybe they'll chime in....
Old Jun 4, 2009 | 03:18 PM
DogRam's Avatar
MikeyB
Fixed by pulling Fass fuse and relay along with abs fuses as per Bob W's instuctions.
Even took out fuel heater fuse.
MikeyB I took your advice and charged up batt's first.
Old Jun 5, 2009 | 01:50 PM
garbri's Avatar
What causes this?
Is there a way to avoid this from happening in the first place?
Old Jun 5, 2009 | 03:49 PM
defleshed's Avatar
Originally Posted by garbri
What causes this?
I'm not an expert on vehicle communications, but i do a lot of industrial programming, rs-484 rs-232 serial communications, and they are very sensitive to voltage, so maybe the draw of accessories or the low battery voltage from having the key on without running for extended time, or just the voltage change from devices starting and stopping might be interuppting the communications between the smarty and the vehicles ecm, causing your errors. all downloaders etc say to turn off all accesories while downloading, so removing abs and fuel pump power is just going one step further at reducing voltage fluctuation while downloading.
stock03
34
Apr 21, 2011 07:40 AM
got_soot
Dec 10, 2010 01:57 PM
Billm2004
18
Sep 1, 2008 03:00 PM
MegaCabRam
Aug 8, 2008 02:01 PM
bnold
39
Jun 4, 2006 08:21 AM
