Smarty--different version
Old May 3, 2007 | 10:39 PM
TORQUE BEAST's Avatar
Got the smarty today and was checking it out. It has 4.06 and 2.07. I noticed on the website there is version 2.08 What's the difference in the two programs? Also how do you enable the high idle?
Old May 3, 2007 | 11:42 PM
jgiachino's Avatar
High idle is enabled on any smarty software....just turn on cruise control and hit set (no touching the brake pedal)....accell / decel increase / decrease the idle speed....
2.08 is the latest....fixed an issue or two with 2.07...you should upgrade....
Old May 4, 2007 | 12:14 AM
I'll try it again. Do you know what the issues were?
Old May 4, 2007 | 12:21 AM
tbarbee1's Avatar
does the high idle work on the 6spd?
Old May 4, 2007 | 02:04 AM
jgiachino's Avatar
I think the 6 speed requires a switch of some sort.....create a new post, i've seen it on here before....
Nothing big, just some timming tweeks and remove 602 code....
Old May 4, 2007 | 10:30 AM
dodgezilla04's Avatar
the 6 speed doesnt need a switch, i just installed one because i wanted to. you just jump pin 22 on the ecm to ground. do a search for the high idle thread.
Old May 4, 2007 | 12:18 PM
Big T's Avatar
When running High idle should you use Park or Neutral?
Old May 4, 2007 | 04:44 PM
what different software should I try? stock turbo/inj. with mild tq man. right now but smokes like a train. Need to clear up a little. Also can someone help me through the download process, I've played with it for 6 hrs now and can't get it to work.
Old May 4, 2007 | 08:39 PM
jgiachino's Avatar
Not sure if it will work in Neutral.....use park.
Old May 4, 2007 | 08:52 PM
annabelle's Avatar
Use N. It keeps fluid circulating to the TC. If you have a modded VB it may do it in P. Stock VB will not.
Old May 4, 2007 | 09:56 PM
Danderson's Avatar
'07 six-speed fix.
Originally Posted by giacchino
I think the 6 speed requires a switch of some sort.....create a new post, I've seen it on here before....
Nothing big, just some timing tweaks and remove 602 code....
My '07 six-speed was leaving a po602 code and the "MIL" light on after restoring the stock program. New download fixed that. I lost some sleep, but Marco and Bob came to the rescue! I do wish a lower initial smoke program were available. I unintentionally smoked out a car behind me that was trying to snake me. That was on #1!
Old May 4, 2007 | 10:30 PM
CarcajouCummins's Avatar
Mine still sets the 0602 code after the update.
jhenson
Sep 8, 2012 10:37 PM
Fisherguy
29
Aug 6, 2009 12:45 PM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
Viperdew
Aug 10, 2006 08:29 PM
