Smarty and built trans settings/power
Old Jul 9, 2011 | 05:31 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Ok,ok don't beat me up for not searching I'm lazy. So I am not used to being on a budget, and this is the longest I have had a stock truck. I can only do one mod at a time and not throw parts at it,( which actually has made me appreciate it more).
now my?
I have a stock truck with Smarty pod s-06 and a billet DTT trans. What the heck do I do with it? I am not going to be able to add any mods for a while so what settings can I run with a stock turbo, what software version, and what kind of power can I make? I am used to having TNT- R twin everything and being able to run whatever I want. Oh how times have changed.
Anyway any advice would be great. It's going to be a long while before I can add a hair dryer, or sticks so I need a good set up.
TIA, Rye.
Old Jul 9, 2011 | 10:47 AM
bigwheels94's Avatar
I would say to start out with the std. revo on SW7, or9, & tune accordingly 'till your truck likes it. Or you could go straight to TNT, & again tune to suit. But I don't know anyone running a stock turbo with TNT. Could probably do it if you start on say SW5.
Old Jul 9, 2011 | 04:06 PM
CLICKBANGBANG's Avatar
I'm on a factory programed S-06 (pre revo). Without the boost fooler listed below and factory sized tires, I dyno'd at 474/ 930 with the stock turbo. Depending on the difference between the trans and rear end, you would be doing close to this.
I'd get a BHAF and a 90% elbow and make a intake on the cheap like mine (vs the $500 kits). For sure gauges on the EGT and trans. Exhaust when you can.
Also update the software to the REVO. My truck is only doing 28 lbs of boost with the S-06. I put the boost fooler on, and it pegs the 35 lbs gauge. I'm thinking the newer software much better. It seems the guys with the updates are doing more boost and a little more power than what I am.
Old Jul 10, 2011 | 12:39 PM
N.Johnson's Avatar
Kind of in the sit as you. New Dtt build with a triple TC. Stock turbo maxed out with revo on 7,tq 3, rp & tm default. Looking at a BD killer B turbo. I am having a wicked harsh downshift to first gear. Wonder what is causing it? Bill set the VB up for towing, less aggressive. Stop and go city I shift to neutral coming to a stop. Any ideas from the forum?
Old Jul 10, 2011 | 02:07 PM
RyeThomas's Avatar
I would deff give them a call. I every now and then would get a hard downshift to one, but not that often and I just attributed it to driver error . But call them you should never have to shift out of gear.
nvr-enuf
Apr 23, 2011 12:43 AM
studio5o
16
Sep 17, 2010 06:35 PM
1985cucv
Feb 18, 2010 02:03 PM
jesussaves
Dec 30, 2009 06:35 PM
stevenknapp
27
Jul 10, 2004 01:11 AM
