Smarty and ABS light
Old Feb 12, 2007 | 02:53 PM
lowboy18011's Avatar
Just downloaded Smarty for first time. I downloaded SW2 and now my ABS light is on. I never have had any codes prior to this and have never used another downloader. Any suggestions? I bought Smarty from DTR performance shop so I have no idea how to get ahold of Bob Wagner and communicating w/Marco is an email and wait a couple days kind of thing. Hoping to solve this today. Thnx.
Old Feb 12, 2007 | 03:02 PM
BLACK PEARL's Avatar
Drive it and it should go away. Smarty reset the ABS system. No harm done. If it doesn't go out then give Bob a call. My ABS light does the same thing ever time I return to stock and down load an update.
Old Feb 12, 2007 | 03:20 PM
WUnderwood's Avatar
yes, after a few key cycles, the ABS light will go off
hope this helps
Old Feb 12, 2007 | 04:13 PM
Mark1si's Avatar
Mine goes off after about 20' of driving.
Old Feb 12, 2007 | 05:17 PM
dodgezilla04's Avatar
contact via Pm, marco or bob wagner. just do a members list search. they will respond. i occasionally get the abs light when reloading, and it is off before i have backed out of the driveway.
Old Feb 12, 2007 | 06:26 PM
Thanks for all the feedback. I actually plugged Smarty back in and checked for codes, none were present so I re-programmed SW2 and ABS light went out. All is fantastic! Drove it around for about an hour playing w/Banks PDA and the new Smarty program and I can make this thing smoke like crazy. W/Smarty on SW2 and playing w/levels 2-3 on PDA while adjusting fuel parameters through PDA was giving boost levels of up to 42psi(stock turbo), lots of smoke(basically smoke on demand), and slipping the crap out of my clutch(anticipated this, Banks could slip clutch on higher levels). The high idle feature alone is cool as heck. I tried for a month last year to get this feature enabled through dealership with absolutely no luck (grounded pin and all), techs at two local dealerships knew nothing about this feature and apparently I wasn't smart enough to know about these kind of things. I am a very pleased Smarty customer right now.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
sssmaly
Jul 13, 2007 12:57 PM
mr T
Feb 24, 2007 06:42 AM
