Slipping torque converter
Old Jul 8, 2022 | 10:56 PM
James Birdsong's Avatar
Exclamation Slipping torque converter
Hey guys, I haven’t checked in in a while. I’m having, what I believe is my torque converter slipping when pulling my 10,000 lb +, 5th wheel up steep grades. My trans temp starts heating up dramatically when I’m in lower gears, (48re trans), but will cool down as soon as I reach the top of the grade. I’ve changed out the trans cooler, which helps, but doesn’t fix the problem. I purchased a “ATS” transmission several years ago, and had to have it rebuilt about 2 years ago with about 35,000 miles on it. Still with the rebuild and another torque converter, (I don’t believe it was a heavy duty one) the problem exists. No issues when flat towing or not towing. The only common issue is I have a Banks 6 gun tuner. I’ve been told that the Banks tuner will send a code to cause the converter to slip if it thinks it may cause engine problems. Has anyone else had this issue? Banks doesn’t seem popular on this forum, but I live in California and need to get smog checks yearly. Any advise would be greatly appreciated. Thanks in advance, Jim.
early 2004, (235 hp), banks intake elbow, cold air intake, banks 6 gun tuner.
mtdoragary
15
Aug 12, 2013 03:27 AM
blackimpala
Feb 5, 2010 11:20 PM
zack birge
25
Feb 6, 2008 11:25 AM
12valve
15
Sep 26, 2006 11:21 PM
dodge 3
Jun 9, 2005 06:35 AM
