Sledpuller 66 Installed/ Question
Old Aug 5, 2005 | 06:46 AM
pcburnout's Avatar
Well Sledpuller 66 turbo is installed what a pain in *** to install but well worth it!
I notice I blow alot more Black smoke now?
EGT's are about the same if not more I thought bigger turbo lower EGT's?
Also notice turbo lags at first but when she spools up watch out. Does this turbo need to have chip set on higher numbers most time?
Seems to get alittle detention at first when getting on pedal?
Any Ideas or help to these question! Thanks!
Old Aug 5, 2005 | 10:10 AM
Meatball's Avatar
sleddie 66
yea i just put one in my 02 last night, it takes a while to spool, 2k rpms i got the fuel. i noticed on a long pull that max boost was 31.9, i thought they set the wastegate at 40-45. you think i should turn the wastegate up.?
Old Aug 5, 2005 | 10:23 AM
sleds's Avatar
The turbo will spool better when you get some miles on it. Egt's could be higher at lower rpm with it because of lower boost, which is why your seeing more smoke. Meatball, my truck made it's peak hp at 2800 rpm, so I would upgrade to the drag comp. Boost on level 5 is 48psi. I wonder if your xmonitor is reading correct?
Old Aug 5, 2005 | 12:40 PM
Meatball's Avatar
i think its reading right, cuz my hx 35 was puttin out 38 psi, that seemed right. i think a mad ecm will give it some pep, i heards ome things about it not workin as well with and edge. but better with just a fuel box (tst)
Old Aug 6, 2005 | 08:36 AM
fahlguy's Avatar
Big singles definitly like fuel..........and lot of it to spool them!
Old Aug 6, 2005 | 06:42 PM
pcburnout's Avatar
I have 100hp injectors now!
Could be i need a fuel box? TST? and a stack or two
Cumminsdieselboy
Jul 13, 2005 09:12 AM
502502
14
May 20, 2005 06:14 PM
Meatball
Mar 24, 2005 08:14 AM
WhiteSport600
35
Feb 18, 2005 10:45 AM
