Finally got a chance to install the SLEDPULLER 66 !!
Old May 17, 2005 | 10:38 PM
502502's Avatar
First off, Thanks go out to Jstieger that wrote the thread on tips for installing any of the HTT line of turbos, That helped a bunch
Now then, the install when smooth - Though it would have been nice to have someone help, But it was getting sick of waiting (on a side not, THAT BOOGER (SP66) is heavy!!! and I'm only about 150lbs soakin wet)
Having the tire and wheel well liner out was SOOOOO nice, made the 15mm bolts alot easier to get off...
Now on to the results:
I'll be frank, When I first pulled out and gave a little fuel (after warmed up), I was very unhappy, it was super laggy, and the EGT was stupid high, and the smoke was really heavy, just as heavy as the with the stocker... I was thinking "why, oh why? did I want this thing" --- So I get home and put on the full exhaust (i was running with just the downpipe to go to sears and get a special socket to install the 4th bolt to hold the turbo on.. Yes, I ran with only 3 bolts holding that 38 lbs on the engine (in hind-sight, not the startest thing to do, BUT how else do you get there?) - I think that might be why the first run was terrible, I guess it leaking exh gas out and not spinning the turbo...
After the exhaust was back on, with muffler (thank the lord) - Things went a little different. The spool up was still slow, but only a little worst than stock... WIERD though, the truck felt "peppy" and no smoke till 12psi, Gotta love the singles program , This turbo needs the TWINS program BAD!! - But after 12psi, it would absolutely rip, BUT the EGTs would still hit 1400 on a run up to 100 mph, I'm like ***? I though my EGT problem would be almost gone... Well anyway I guess I under estimate the fueling capability of the TST, because this truck was at 105mph, and at redline WAY faster than with the stock turbo... THe dyno will tell it all
BTW - level 5/4 feels about like 6/5 did with the stocker, AND the egts leveled at about 1350* --- We will see after a few weeks if it loosens up
Some pics for your enjoyment:
http://www.turbodieselregister.com/f...d.php?t=130810
Ohh yeah
Two more things:
1) Cutting on a $300 intake is very sucky (to make room for the intercooler piping, But you gotta do whatcha gotta do
2) the stock rubber intake hose from the turbo to the AFE is VERY,VERY,VERY tight fit between the compressor outlet and the shield on the exh manifold... Looks like a torque tube is in my future
One last thing, At 38psi on the stocker, I would NEVER pull the filter minder down, BUT with this SP66 at the SAME psi, the sucker is WAY down, like its telling me I need a new filter pretty darn soon, Food for thought
Old May 18, 2005 | 07:27 AM
Fat Asp's Avatar
Tommy are those dyno #'s the old ones. On TDR you sig has 458/895. Have you dynoed the SP66 yet?
Old May 18, 2005 | 08:35 AM
AK RAM's Avatar
A 300 degree drop in EGTs isn't that bad, but with a turbo that big I would have expected maybe a little more as well.
Have you really poured the fuel to it yet? Since it takes a little more power to drive my twins, they actually cool better the more I turn the fuel up and put my foot in it. You may find the Sledpuller is about the same when you get to where you can really drive it hard. That is a pretty big turbo and no doubt will take some decent energy to make it earn its keep.
Old May 18, 2005 | 04:52 PM
502502's Avatar
Just pulled 496 about an hour ago... The TST (singles) program is killing me, Right at 12psi, all hell breaks lose, and i'm at 40psi like now
I will see what happens when I get the Twins program
Old May 18, 2005 | 05:47 PM
AK RAM's Avatar
What were your TST/EZ settings on that run? Nice numbers.....SO's rule!
Old May 18, 2005 | 06:07 PM
Don M's Avatar
DTR Advertiser
Time for sticks! 530, 540, 550, 560? Hmmm??
Don~
Old May 19, 2005 | 11:36 AM
cquestad's Avatar
I personally know somebody that is ready for sticks too...by the end of June.
Real personally.
Old May 20, 2005 | 12:24 AM
mattymac's Avatar
Don~
Yeah and with about the same EGT's.
Old May 20, 2005 | 12:44 PM
502502's Avatar
7/6 -- And EZ on level 2
Get this, I tried TSt 9/9, and only got 409hp -- BUT a WHOLE LOT OF SMOKEY FUN!!!
DON - getting close
Old May 20, 2005 | 01:01 PM
WhiteSport600's Avatar
Put a Crazy Larry on it! Your EGT's will drop, your power and smoke will go through the roof! At least they did on my 600...
Old May 20, 2005 | 01:12 PM
502502's Avatar
Quads got a few extra downloaders, I might grab one, But they do scare me a bit
Old May 20, 2005 | 01:30 PM
I've got my Sledpuller set to 45psi, it seems to hit the "sweet spot" of it's cooling abilities around 40-50psi.
As far as downloaders go, as long as you don't hear a bunch of timing rattling before the turbo spools, it's fine. After it spools, you've got nothing to worry about except speeding tickets. Tomey- Be sure you get the Crazy Larry program(230hp), it's a world better than the old 130hp setting...
Old May 20, 2005 | 04:44 PM
RadRam's Avatar
Can you get the Crazy Larry program for a 03 or 04 ? I dont think so.
Old May 20, 2005 | 05:57 PM
cquestad's Avatar
RadRam...have you dyno'd your set up?
Old May 20, 2005 | 06:14 PM
I honestly don't know if it works on the 03-04...hmm that's something to find out. I know my CLDL still says 03up on it...
bigfoot
Dec 16, 2006 03:42 PM
BC847
Nov 6, 2006 06:19 PM
napa 600
Feb 23, 2006 11:12 AM
napa 600
Feb 18, 2006 08:15 PM
napa 600
Feb 1, 2006 06:14 PM
