Silencer Ring
Old Feb 16, 2007 | 07:08 PM
stockton's Avatar
Silencer Ring
what is the function of a silencer ring? what is gained by removing it? and how is it removed? any information on silencer rings is appreciated. just a note I recentley installed the quadzilla standard dispite the electronics box looking like it came in a shrek happy meal seems to work as advertised can't tell any difference between power levels 2 and 3.
Old Feb 16, 2007 | 07:24 PM
BigBLu's Avatar
Silencer ring is what it says it is, if removed your turbo will get a little louder but no power gains just sounds alot cooler.
To remove just pull your airbox elbow at the turbo, you will see the ring in the turbo, there is a c clip holdin it in. Just take a screwdriver and pry the c-clip loose the rest I did with my finger. Real easy to do.
Old Feb 16, 2007 | 09:16 PM
Ghost Ram's Avatar
the "silencer ring" protects against surge. at least thats what its for on most turbo applications. im not sure exactly what dodge inteded it for.
Old Feb 16, 2007 | 10:04 PM
gman07's Avatar
The silencer ring reduces noise and slightly improves compressor efficiency.
An MWE slot, or ported shroud compressor housing is what protects against surge; a byproduct of the slot is noise, which the silencer ring reduces. The silencer ring can in fact make surge worse with small exhaust housings by blocking the flow coming from the MWE slot.
Old Feb 17, 2007 | 05:30 AM
gimmie11s's Avatar
That's incorrect.
The compressor housing on these turbos is an "anti-surge" housing. Putting a ring over the anti-surge ports will actually create MORE surge. Dodge did it to quiet the turbo down... plain and simple.... guess they're not interesed in keeping turbos alive.... just keeping them quiet.
dd
Old Feb 17, 2007 | 09:36 AM
magram's Avatar
So has anyone run into any problems from removing it?
And can it be put pack it as easy as it comes out?
Is the old one that you take out wrecked, or does it have to be replaced with a new one, or can it be put back in?
Thanx
Old Feb 17, 2007 | 09:42 AM
bdewey's Avatar
Removed mine in under 10 seconds and could be put right back in. Like said above it is a snap ring holding the metal silencer ring in. All you need is a flat-tip screwdriver.
Old Feb 17, 2007 | 10:01 AM
t-boe's Avatar
When my intake and exhaust come in I'll post some pictures when I take mine out.
Old Feb 17, 2007 | 10:31 AM
Townsend600's Avatar
I had better luck removing mine with a small 90 degree pick.
Old Feb 17, 2007 | 04:20 PM
TORQUE BEAST's Avatar
so you are saying that it is actually better for the turbo to take the silencer ring out?
Old Feb 17, 2007 | 04:31 PM
HotRodK's Avatar
Wink
I actually finally got mine out today. Since I already have a modded airbox and Amsoil filter, I could hear a difference in the turbo. Its not night and day, but the spool sounds different and the full boost whistle is a bit louder.
Oh, my clip was a PITA to get out. I didnt go crazy and rip out the silencer ring like someone else, but it really tested my patience. I finally got it out with 2 flatheads and a lot of patience.
Old Feb 17, 2007 | 07:04 PM
matt ellerbee's Avatar
first post and mod....
did this today as well, the hardest part was getting the intake piping back on
Old Feb 18, 2007 | 08:49 AM
HotRodK's Avatar
Wink
How was your clip oriented? The gap on mine was up near 1 or 2 'o clock. I couldnt hardly see what I was doing, much less get my big hands up there. That was my biggest problem. Im soooo glad thats over. I may never mod again.
Old Feb 18, 2007 | 08:59 AM
txfiremedic's Avatar
My clip was oriented at about 5 'o clock. Super easy to get out!!
Old Feb 18, 2007 | 10:06 AM
Need More Info.
Originally Posted by gimmie11s
That's incorrect.
dd
so, is it better for my turbo to take the silencer ring out? I know there is no performance gain but don't want my turbo to die anytime soon either. I've got free time today to remove it if I need to.
