Should I do the s400 or s480 MPI's......
Old Apr 21, 2008 | 01:03 PM
John_P's Avatar
Originally Posted by Mcmopar
Going for more???
OH YEAH!! I have to try and keep up with all these CR trucks Phil!
Old Apr 21, 2008 | 07:10 PM
nrussell's Avatar
Originally Posted by Justice4all
Before you spend money on it you ought to try to see how the Silver will do in its current form. You might be pleasantly surprised and you'll keep the lower drive pressures that come with the 74mm wheel. If the lag truly is more than you can handle then send it to II to change out the wheel.
I guess I will wait to see how my silver62 work's with the s400 I think it will be fine, because with the smarty and tst now, she does get up and go very very quickly.
Old Apr 21, 2008 | 11:55 PM
Idaho CTD's Avatar
The 73mm turbine wheel (SB size) is actually designed for a low rpm motor so it will do well in twins where it doesn't do a lot of work but flows well. The down side is the small wastegate size in the cast housings for making really big power. Up to 7-800hp it should be fine though.
Old Apr 22, 2008 | 12:54 AM
desertchecker's Avatar
I agree give the silver a try......as is & see how it works you can always spend money later and have a 71 or 65 smaller wheel installed if you think it's needed !
Old Apr 22, 2008 | 03:48 PM
nrussell's Avatar
Talked to Nathan today and I should receive kit in 3 weeks.
I am so freakin excited about these MPI twins I can hardly wait!!
Three weeks is going to feel like eternity.
Old Apr 23, 2008 | 08:32 AM
53 willys's Avatar
so you went 62-S400 then?
congrats on your new toys!!!
Old Apr 23, 2008 | 09:24 AM
GaveUpOnTV's Avatar
s300/s400 that's a classic hot setup, Nathan's website says low 700 hp range, that's big power in my book!
http://www.maximizedperformanceinc.com/pricing.htm
Old Apr 23, 2008 | 02:50 PM
nrussell's Avatar
Yeah I am sticking w/my silver62 and s400. Nathan said it's 700-800hp range with this setup. That is more than sufficient for my needs.
diggity dodge
Aug 18, 2008 12:45 AM
homewrecker
14
Jul 1, 2008 10:48 AM
mykal41
23
Jun 6, 2008 12:42 AM
diggity dodge
May 23, 2008 05:38 PM
