scottyIII?
Old Nov 21, 2003 | 01:24 AM
danshsss's Avatar
scottyIII?
Who has the best price on the scottyIII ???
Old Nov 21, 2003 | 05:39 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:scottyIII?
www.wildcatdiesel.com
Old Nov 21, 2003 | 11:04 AM
roperdog's Avatar
Re:scottyIII?
i would shop between www.wildcatdiesel.com and www.westtexasdiesel.com . wildcat diesel makes them and sell them....west texas sells them.
Old Nov 21, 2003 | 11:06 PM
Dr. Evil's Avatar
Re:scottyIII?
I think you can get the Scotty intakes just from Wildcat Diesel....
Old Nov 22, 2003 | 08:29 PM
03CTDCO's Avatar
Re:scottyIII?
Will installing the ScottyIII air intake system void any part
of the 7/70 on a 2003 HO 2500HD?????
Does it meet or exceed Cummins requirement for proper
air filtration???
Old Nov 22, 2003 | 10:41 PM
BADBOWTIE's Avatar
Re:scottyIII?
I don't believe that the filter in a scotty III meets the Cummins specs. Many guys run them with no problems but, if you want to change things you must be prepared to be your own waranty station.
Jason
Old Nov 22, 2003 | 10:54 PM
Dr. Evil's Avatar
Re:scottyIII?
[quote author=BLUE04 link=board=49;threadid=22675;start=0#msg212951 date=1069562515]
Jason
[/quote]
or put your stock airbox back in before going to the dealer...
Old Nov 23, 2003 | 10:22 AM
Agades's Avatar
Re:scottyIII?
[quote author=Dr. Evil
well yah! :
dont you remember
"No mom I didnt have my hand in the cookie jar"
Old Nov 23, 2003 | 02:12 PM
03CTDCO's Avatar
Re:scottyIII?
Does anyone make a high flow aftermarket drop in
panel filter that meets Cummins specs?
Dont you have to drill a hole in you inside fender
to use the Scotty III correctly? I thought I read that
somewhere.
FiverBob's Avatar
Re:scottyIII?
It is my understanding it exceeds the filtration requirements and definitely gives more flow. My dealer did not object, in fact commented on the huge filter and that Dodge could take some lessons from other companies - - it would not cost as much to make a RamAirIII as the factory unit.
Old Nov 23, 2003 | 02:34 PM
Shovelhead's Avatar
Re:scottyIII?
The hole drilling is only on the 2nd gen using the Scotty II.
The Scotty Ram Air 3 is a bolt in install.
As for the Aftermarket air filter question, anything that deviates from bone stock can affect your warranty.
Old Nov 23, 2003 | 03:23 PM
03CTDCO's Avatar
Re:scottyIII?
Who has pictures of a Scotty Ram air III
installed on a 03 or 04 HO?
Thanks
Old Nov 23, 2003 | 03:47 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re:scottyIII?
[quote author=Shovelhead link=board=49;threadid=22675;start=0#msg213133 date=1069619662]
[/quote]
Ed, you make a great point here. Cummins and Dodge intensely dislike any kind of oil based filter, whether the manufacturer says it meets or exceeds Cummins/Dodge spec or not. In order for the filter to not void a warranty, the filter would have to be put through standardized testing by an independent facility. To the best of my knowledge, aFe, K&N, Green or any of the other filter manufacturers have not done this.
Rod
Old Nov 23, 2003 | 03:50 PM
Push Rod's Avatar
Re:scottyIII?
[quote author=03CTDCO link=board=49;threadid=22675;start=0#msg213159 date=1069622586]
[/quote]
http://www.wildcatdiesel.com/ra3.htm has a shot of the Ram Air III installed on an 03. Its not a great pic of the entire underhood, as we ran out of room on the web page, but it should give you a little better understanding of how it looks.
Please note, this is an older version of the RA3 with the filter minder in the wrong spot :-[
Rod
Old Nov 24, 2003 | 11:00 AM
Scotty's Avatar
Top's Younger Twin
Re:scottyIII?
;D
