Schaeffer 9000 Is Cj4+ Is It Ok In 5.9 ?
Was looking at getting Schaeffer 9000 syn oil for my 07 5.9 that calls for CI 4 or CI 4+ and just found out the Schaeffer 9000 is CJ 4+. Rep says it is the better oil and is backwards compatible - what are ya'lls thoughts on this.??
Yes it is backwards compatible and it will work. You can still buy CI-4+ oil so why not use it as I think holds up better then the new CJ-4 oil. Also with you having a Smarty you need all the extra protection you can get for your engines internal parts.
JMHO
JMHO
Just read owner manual again and it only calls for CI 4 and +, but is this just because the CJ4 wasn't out yet or the fact that the printed manuals weren't revised quick enough, or was it only meant for the 6.7 and later engines. It seems the Valvoline Extreme is the only recommended oil by Cummins, but the owners manual says all are ok if it meets there specs, so what is or which one to go with ???
I just bought schaeffers 9000 syn for my 05. I have truck drivers run this in there trucks and go 20,000 miles on changes and send off samples and they come back normal. They also claim better mileage!!
JMHO
Did I read this correctly? Shaeffers 9000 is a CJ-4?. I was on another thread and was of the understanding it still was CI-4. I just bought the new Redline diesel synthetic...Too bad its CJ-4 too. Does anybody know of any Synthetic that is truly CI-4
My local oil distributor has bulk CI Delo 400 and gladly fills 5 gal pales for me at a very good price. I was told a lot of the fleets arround here use it. Check with your local distributor.
Buy all the old CI you can get.
From what I have read the CJ like mentioned above has been modified so as to not clog up the after treatment system on the new diesels.
The ingredient removed from the oil is ZDDP if I remember correctly which is a wear inhibitor.
I would advise running an oil additive containing ZDDP or similar additive product to bring the oil back up to snuff (Lucas oil stabilizer, STP oil additive etc.).
Yes, ZDDP has been REDUCED. It has not been "removed" from the oils. Use of oil additives is not necessary, the oil companies formulate their oils to work as they should without the end user having to add anything extra. Furthermore, CJ4 oils are now being formulated with more ashless antiwear chemistry, thus putting back if you will, any amount of antiwear additives that were lowered.
The oil companies have lowered ZDDP, TBN, amd ash levels in CJ4, but they have also changed the chemistry to accomodate even better wear protection to combat increased soot in the oil. CJ4 has also shown to have its TBN depleted slower when using ULSD, which should always be run when using a CJ4 oil to take advantage of the longest possible intervals.
I believe the Amsoil 15w-40 synthetic remains CI-4, CI-4+ with all the good additives, while the Amsoil 5w-40 synthetic is intended for the trucks with the particulate filters and carries the appropriate CJ rating. The CJ oil is backward compatible, and the CI oil "officially" is not forward compatible with the new emission controlled trucks. Since synthetic oil is not as volatile as conventional oil, the synthetic CI oil may work fine in the newer trucks since it will do a better job of retaining it's additives, however, I understand the testing organizations don't consider the volatility difference. In summary, if you have a new truck that requires the CJ rating why take a chance on using a CI, if you have a truck that calls for CI then use it if you can find it. I would rather use a synthetic CI than a synthetic CJ.
