SB or Haisley DD clutches
Old Nov 15, 2005 | 02:44 PM
StevenB05's Avatar
I am going to buy a clutch and don't know which one to buy South Bend DD or Haisley DD street drag. I tow around 10k, I like to race those maxipads and powerjokes around town. I wounld also like to take it to the drag strip ever now and then. I only have a qaud race box now but would like to grow maybe a bigger turbo and tst stacked or something around that nature. I have been known to be a little rough on my stuff but not to bad. Any suggestion on which would fit my needs better and any personel experience.
Old Nov 15, 2005 | 04:18 PM
WhiteSport600's Avatar
I have the SB 3650 12cb DD clutch. It's a little hard on your leg, but the holding power is out of this world! I've done hundreds of 3rd gear 4x4 launches when drag racing, and quite a bit of sledpulling as well. I think the Haisley is easier on your leg, and maybe a little more streetable if you never plan on sledpulling. The SBC clutch has the superior Borg & Beck style pressure plate, that's why I picked it...
Old Nov 15, 2005 | 04:31 PM
strokethis600's Avatar
i have the haisley drag twins and absolutely love it. however if u want to do some sled pulling then i would suggest the street puller. besides being a good cluch, haisleys are the most knowledgeble people when it comes to the ctd and are great people
Old Nov 15, 2005 | 05:32 PM
Rick D's Avatar
I have the SB 3600 12cb DD clutch, with the stock hydrolics, pedal was stiff and hard to shift, but after installing SB's hydrolic upgrade, the pedal is like stock, and a real pleasure to drive.
but it is noisey, but no more or less than a haisley.
Rick D
Old Nov 15, 2005 | 07:34 PM
fordper4mance's Avatar
I just installed in the Haisley street drag about 700 miles ago in my truck. It is still on stock hydraulics and hasnt had any trouble but someday i will probably switch them out for the 12v type setup. It holds very well, but requires a little more rpm's on take off to make it smooth or else you get a little chatter. Overall quite happy with my decision.
Old Nov 15, 2005 | 08:02 PM
banshee's Avatar
My Street Drag has taken a beating and it keeps coming back for more! I've had it for about 25k miles now and haven't had any issues with it. I have done countless 1/4 mile passes with it and it holds fine and shifts very fast. You can see my power level and 1/4 miles times in my signature. I would buy it again without question.
Old Nov 16, 2005 | 01:43 AM
PourinDiesel's Avatar
If your just going to drag race and tow it sounds like the Haisley street drag is better suited for your purposes.
Old Nov 16, 2005 | 07:40 AM
cmnspwr's Avatar
Why not a Zoom clutch? They are a variable plate load clutch up to 4000 lbs at ~3200 rpm, but will go a little higher. Saw it on a clutch dyno at SEMA, where it showed 3977 lbs at 3175 rpm. All this done with a button type single disk.
Old Nov 16, 2005 | 07:46 AM
StevenB05's Avatar
I am leaning more to the haisley street drag. I want fast shifts too is the south bend a slow shifter clutch. Also would the haisley street drag hold up to one county fair sledpull a year. thanks for the help so far men
Old Nov 16, 2005 | 08:36 AM
banshee's Avatar
The Street Drag should hold a sled pull here and there just as long as you don't slip it a lot when pulling out of the hole. The friction material holds very well and can be modulated/slipped some for smooth takeoffs or high RPM drag launches, but I don't think you'd want to ride the pedal for 100' with a sled behind you.
Old Nov 16, 2005 | 12:26 PM
The only thing you have to worry about with sled pulling with the drag twin is you have to launch at under 1500rpms. or atleast that is what i was told.
Old Nov 16, 2005 | 01:00 PM
Thats about impossible.
Old Nov 16, 2005 | 03:24 PM
Kman9090's Avatar
that I am pretty sure is impossible. I had trouble slipping my stock clutch in between 2000-2200 Rpm so 1500 would be down right insane.
Old Nov 16, 2005 | 05:30 PM
cantfindaname's Avatar
I not sure which is better but I do know that Haisley's build very good products and stand by them as well. I know the Haisley's very well(grew up with Curt) and like someone said earlier, they are very knowledgeable when it comes to CTD.
Old Nov 16, 2005 | 07:03 PM
Ya its not fun because you have to use a low gear. I used 3rd low and you just cant get enough wheel speed.
