S&b - Wheres The Whistle
Installed the S&B intake and filter but didn't notice hardly any whistle. What gives. I also couldn't figure out how to get the "silencer ring" out, didn't want to pull or tug on it, what am I or did I do wrong.??? There are also 2 white "fins" down in the last turn going into the turbo I guess to help direct the air flow, do the come out or what ???????
Everything else went fine with install pretty straight forward.
Derek
Derek
Cool, so there must be like a snap ring in front of the bigger silencer ring then and I must have not seen it. Did yours have the "fins" or vanes down in the tube as it turns into the turbo ??? My silencer ring was marked with a green dot and also a green dot on the turbo housing like a reference point, did yours have that also.?
Isnt the S&B a sealed enclosure? My Brute Force is open and that thing sings. Also, the silencer ring is in the opening of the turbo itself,right before the impeller. One side of the snap ring is flat and the other is angled. All you have to do is slip a flat head screw driver under the angled side of the snap ring and gently pry it up and out of the groove. Mine popped out really easy.
Derek
Derek
Derek
Yeah, mine had both the markers as well. Did ya get that snap ring and silencer ring out yet? I also DID have the vanes leading to the impellar, so all that's normal. Just get the snap and silencer rings out and bolt everything back up good and tight. Should be yellin atcha...you're GONNA wanna drive it. You done or doing an exhaust anytime soon? That will help the breathing and make the whistling louder a bit too
Derek
Derek
yes I've got the Magnaflow straight thru muffler, kitty still on, only have 1600 miles on here, thought I'd better wait on that part.....
