rubbing with 315's
rubbing with 315's
I have a spacer (similar to a leveling kit) on the front and a block in the rear of my truck. (I bought the truck from the guy that placed them, so I don't know the specifics.) But, I have 315-70-17 on my truck and I have noticed where the tires are rubbing and have almost worn a hole in the wheel liner. Is there anything I can do about this besides the obvious (change to smaller tires or lifting the truck further?)
Thanks
Thanks
thinking your wheels have a 4.5" backspace. If so your wheels will stick out of your wheel well a couple inches.
That being the case, there is not much behind that part of the wheel well liner. I would just remove that part of the liner, no big deal. If you look at my photos you can see some pics of what is behind the liner, this should give you a idea of what you can remove.
If you had a more stock offset you shouldnt be having this problem. Most people dont any way, I did not.
good luck.
good luck.
Iwantadodge
Dec 1, 2009 08:25 AM
getblown5.9
Jan 1, 2007 06:22 PM
