Rough Idle
Rough Idle
my buddy has an 03 that idles at 1800 rpm's and right away droppped to 350, but the whole time runs rough and it hunted (rpm's) it has no codes.also it makes growling noise by or at the cp3.it has been doing this since summer.no dealers could diag. thanks
Yep they will swap out. Unplug the sensor on the back of the fca valve and see if it changes the way the truck is idling like stated ^^ it sounds like it could be sticking. If you have a good fca laying around and a few spare minutes it may be worth seeing if it will fix the problem it will take you no time to do the swap.
banks twinram
May 18, 2010 08:10 PM
turbov6joe
Sep 25, 2003 10:57 AM
