Roll Cage ?
Old Sep 25, 2007 | 10:10 PM
  #31
morkable's Avatar
I am a little worried about losing some of the streetability of the truck with a full roll cage,,,, that is the only reason Im looking at the roll bar
Kevin
Old Sep 25, 2007 | 10:29 PM
  #32
ScienceOfSpeed's Avatar
dont be, i have had a 10 point cage with a halo and solid side bars in several of my vehicles, i loved it, u will not lose any streetability
Old Sep 25, 2007 | 10:51 PM
  #33
morkable's Avatar
im not the most flexable person, and this truck is hard enough to get into as it is
Kevin
Old Sep 25, 2007 | 10:53 PM
  #34
you could put swing out side bars and you should have no trouble getting in and out of the truck
Old Sep 25, 2007 | 11:00 PM
  #35
i am designing my own and i am having a local shop bend up the tubing. all this shop does is tube frame chassis and roll cages, i am going with a 10 point, halo, solid side bars, and i am going to design the back bars so that they do not interfear with the back seats
Old Sep 25, 2007 | 11:24 PM
  #36
templer's Avatar
Mork yeah I agree, you shouldn't lose much in the street aspect. I have a full cage in my 1974 camaro z28. I use it for autocross and canyon carving, well in my neck its mtn carving. But its not bad IMO. If i had to do over i would do the swing out door bar though.
Old Sep 25, 2007 | 11:41 PM
  #37
morkable's Avatar
there is also the cost factor,,, it is considerably more for a cage,,, im running out of money,, lol
Kevin
Old Sep 27, 2007 | 08:31 PM
  #38
Howling's Avatar
Originally Posted by Howling
The cage mounts to the floor with a plate,then on the backside of the plate is more tube that ties into the frame.
Originally Posted by ScienceOfSpeed
for it to be legal the points that touch
the floor board have to pass thru the floor board and be welded to frame. plus that is were your strength of the cage will come from. i am not saying that it would not be strong if u welded the point to the floor but since we have a cab and a frame the cage would be more accurate and true if it was welded directly to the frame
Had me worried so stopped by the shop and looked at the cage to frame tie in.
On the frame there is a 3x2" rectangle tubing that is welded at roughly a 45 degree angle that enters the cab through the floor.The 3x2 is capped and the chrome moly tube is welded directly to the rectangle tube.
Old Sep 29, 2007 | 02:17 AM
  #39
Idaho CTD's Avatar
I had roughly the same done for our cage but our box tubing is 3x4 as we used 2" DOM .150 wall. The box tubing is also ties together with a piece of 2" DOM. If you think you'll ever push 9's then I'd do a full cage. It's easier to do it the first time instead of having to do it again later.
Old Sep 29, 2007 | 02:38 AM
  #40
morkable's Avatar
Im just trying to break into the 10's,,, dont really see 9's,, not with this truck I dont think..... I really think I would have to put the truck on a real diet to get there
Kevin
ps,, Nathan, I still want to catch up with you at some point this winter, to get those twins figured out.
Old Sep 29, 2007 | 11:08 AM
  #41
Idaho CTD's Avatar
Hopefully I'll have some data later on this fall/winter from a few of the big chargers. Then we can get a good plan for a set of twins for you.
Old Sep 29, 2007 | 05:56 PM
  #42
morkable's Avatar
That sounds good to me,, I think that when the time is right I will come to you, and get this all done,, if that would be ok with you?
Kevin
Old Sep 29, 2007 | 07:27 PM
  #43
Idaho CTD's Avatar
That's cool
Old Sep 30, 2007 | 01:57 AM
  #44
morkable's Avatar
Awesome,, it will probably be after xmas, as I am in the middle of major renos on my house right now,, but after I get that done,, then it is time for renos on the truck
Kevin
MOAGGIE
Jan 3, 2011 10:18 AM
johnsjas
Competition / Pulls / OffRoad
May 10, 2008 08:58 PM
ptgarcia
Off Road / 4x4
0
May 16, 2006 11:24 AM
ramlovingvet
Nov 7, 2002 07:54 PM
