rokktech timing sensor
Old Feb 20, 2007 | 09:10 PM
223 rules's Avatar
Is it worth getting the timing sensor to go along with my quad xzt and if so what will it do for my truck?
Old Feb 20, 2007 | 10:08 PM
Brock's Avatar
i putone on my truck with no other chips or mods......helped about 1.5mpg hand calculated and maybe a little smoother start....but that is about it. still have original to go back to if needed...but at the cost and effort it was worth it to try and no loss if it did not. You can modify your own instead of buying one from rokktech with archives here....
Old Feb 21, 2007 | 07:24 AM
MikeyB's Avatar
The Rokktech is a good addition if you're running pressure or duration boxes. The extra two degrees of timing helps in lowering the EGTs.
I ran the Rokktech when stock and also with the Edge EZ. I had to remove it with the SMARTY though, too much timing and rattled pretty bad.
MikeyB
Old Feb 21, 2007 | 07:40 AM
omaharam's Avatar
I honestly didn't notice any difference at all. I did it after exhaust, intake, and regular juice.
Old Feb 21, 2007 | 05:36 PM
223 rules's Avatar
Did your trucks run any better with it or get better mileage when used with the xzt?
06megacabman
Jun 11, 2007 12:11 AM
snowmanx
Sep 10, 2006 11:51 AM
Big Bob
Nov 8, 2005 12:41 AM
isissound
Oct 16, 2005 09:34 PM
Tiara3100
Sep 11, 2005 10:50 PM
