Rokktech crank sensor
Old Jul 26, 2008 | 06:30 PM
palomino's Avatar
Has anyone used a rokktech crank sensor with the bullydog tripple pup, and if so, was it worth it? Have the sensor in the truck, and only difference that I can see is that the transmission seems to shift at a later shift point under light to moderate acceleration..... thinking about downloading the bd, and seeing what happens....but going to wait until the front pump is fixed on my truck....
Old Jul 27, 2008 | 06:37 AM
Hounddog's Avatar
Can't help much but since no one else did here goes,Does the Bully dog box do any or much timing advance? If not use the Rokktech.The Rokktech advances timing about 2 degrees or so.Not much.If by chance you use both and pick up any fuel knock just loosen the Rokktech and move it a hair back to the old position.No biggy.
Old Jul 27, 2008 | 08:23 AM
Patriot2500's Avatar
I ran the Rokktech and BullyDog Power Pup w/Crazy Larry for two years or so. Only difference I saw with the Rokktech installed was the tranny didn't hunt for gears as much at a low speed. I bought my Rokktech used for $40 bucks or something like that, so it was worth it for awhile. I switched to a Smarty a few months ago which does advanced timing so I sold my sensor. If you can find one used, than its worth it in my opinion.
Old Jul 27, 2008 | 08:54 PM
palomino's Avatar
ok, that is what I needed to know. yes, I found a used one, and it makes the transmission shift better IMO, but I wanted to make sure that the bully dog and the sensor could work together.
Old Jul 27, 2008 | 10:26 PM
ducktape's Avatar
Made no difference on my truck other than a tad better mpg for the first couple months of it being on.
sjester
May 10, 2007 05:03 PM
Gabe32
16
Feb 22, 2007 06:37 PM
BigDave12768
15
Sep 29, 2006 08:32 PM
Dixie Chopper
Jun 8, 2006 07:58 PM
Mopar72
May 21, 2006 06:36 PM
