Rocker Arm/Trunnion Wear
Old Dec 23, 2008 | 09:04 PM
tritont's Avatar
any answer on this ??
Old Dec 24, 2008 | 09:13 AM
XLR8R's Avatar
Looks great, Don!
Wish I was already back to install them.
Ty & Eric - if F1 starts offering these, you can bet there'll be 2 different prices for new coated rocker shafts or used refinished coated shafts... Don really did a "labor of love" on these due to the galling.
Old Dec 24, 2008 | 09:30 AM
tritont's Avatar
Originally Posted by XLR8R
Looks great, Don!
well as usual... he couldn't come back and answer a simple question. I assume he just took care of those you for. I'm not looking to have it done and was only curious as to his intention by doing your.
Old Dec 24, 2008 | 09:52 AM
XLR8R's Avatar
Well, it's Christmas week... many folks are spending time with family & friends, and perhaps not concentrating on work as much.
I just figured Don's intention was to help us out with the thumper truck we're building, and get some empirical results for F1's new HPC.
I'm pretty sure we won't be building any more CTDs without addressing the rocker shaft/lever wear issue.
Old Dec 24, 2008 | 09:54 AM
tritont's Avatar
totally understand able but, I posted right after he made his post the other day.
Old Dec 24, 2008 | 09:56 AM
Don M's Avatar
DTR Advertiser
It has been goofy crazy at the shop and I have not had a chance to reply. We are off today and tomorrow, but I would rather be there than face what I have to do today........Christmas Shop!!!!!
The rockers themselves were galled so the only thing we could do is polish them with a 600 grit flex hone. I did not want to remove any more material than we had to. The galling is still there, but they are certainly still serviceable and very smooth now.
IMO, the best way to handle this is to try and get the coating on long before this wear starts. I want to give these and a few other sets a few months and see how everything holds up.
The biggest costs is not the coating, its the finish work to repair the wear. Literally hours and hours. )-:
Old Dec 24, 2008 | 09:59 AM
tritont's Avatar
thanks for the reply Don. Looking forward to seeing how this turns out. It's a obvious problem with all our trucks.
Old Dec 24, 2008 | 10:05 AM
XLR8R's Avatar
You're as bad as I am Don!
We're fixing to head out for a whirlwind shopping tour ourselves...
Old Dec 24, 2008 | 11:04 AM
paulb's Avatar
Those look very good Don. It's something I'm going to have to address in the near future.
Paul
Old Dec 24, 2008 | 11:49 PM
DF5152's Avatar
Is this a wear issue due to current oil specs? or design? a soft material?
Old Dec 25, 2008 | 09:28 AM
XLR8R's Avatar
Natural result of design, aggravated by higher spring pressures, poor oiling history and CJ-spec.
Old Dec 25, 2008 | 01:50 PM
TexasCTD's Avatar
Mike, You think that CJ Blend oil contributed to the wear here?
Old Dec 26, 2008 | 12:00 PM
XLR8R's Avatar
... bet it didn't help.
Old Dec 26, 2008 | 12:21 PM
Don M's Avatar
DTR Advertiser
The rocker design is the same as the ones used since 98.5 when the 24 Valve VP44 came out. This was never a big issue in those years. This is a newer problem. The only changes seem to be the oil blends and the use of higher pressure springs.
The levels of ZDDP is dropping like a rock as the oil has gone to CI and now CJ. In 2010, the levels of ZDDP go even lower.
I think the crappy oil we have nowdays is the culprit. We have never had as many cams with accellerated wear and rocker arms with same as in the last 6 months or so.
Old Dec 26, 2008 | 01:18 PM
DF5152's Avatar
so what can we do? any additives that work?
will this do anything? http://www.eastwoodco.com/jump.jsp?i...-_-ZDDP-_-ZDDP
