rev limiter-can you go higher??
Look at my sig it tells the mods.
Recently I have been hitting 3250 Rpm through a whole run pulling a sled.
The rev limiter is kicking in and the motor just cracks and pops the whole pull. I tried high range once and that was stupid because I didnt have enough tourqe to have any wheel speed. I think if I could get the motor to jump another 600 to 800 RPM it would help me. My question is: Does someone have a box to take away rev limiter or up it? If not, can I safely do something to the motor to crank out some more RPM?
To answer your first question: Not yet.
Next question:
Build every piece to run up higher...springs, cam, fuel, etc. and you will have a much better experience up top and less popping and cracking.
At least thats my experience.
Next question:
Originally Posted by BigBlue
Doesn't a RAD eliminate the rev limiter?
). I think I might try to go back and rehook everything ....it will only be the fourth time
Next question:
Next question:
Originally Posted by cumminsdriver635
You have an automatic. Why not let it upshift?? A higher gear accomplishes the same thing as more rpm's...
Eric
Eric
Here is how I pull. Build 18 lbs boost-launch it, wind out rpm shift to 2nd, wind out - hit lock up switch and run to the end. So...for some reason when I have tried to go ahead to 3rd (with OD off) I lose wheel speed. Not enough power?
I even tried high range once(by accident) and made an idiot out of myself. A ford beat me
Dan, With SMARTY and my overfueling I'm able to blow by 3500 to about 3700 in all gears and I'm an SO.
ks. Note that there is no torque management so parts will definitely be challenged.....I use my RAD for top speed elimination only. ks
