Remote oil filter?
Old Nov 14, 2006 | 02:19 AM
acook's Avatar
Remote oil filter?
After my twin install im going to have to pull my IC pipe and my intake pipe to get to my oilfilter so is their a remote oil filter that i can get to relocate it to an easier spot to get to? Where can i get it, whats the cost, and are their any negative effects to it?
Old Nov 14, 2006 | 03:18 AM
morkable's Avatar
I would look at the fs2500. I am not sure of the cost, I think it is around 400 here, so it would be less down there, and you should be able to get it from just about any dealer, they have a web site too,,, www.fs2500.com
Hope that helps
Kevin
Old Nov 14, 2006 | 04:32 AM
PowerDually's Avatar
Look on ebay. you can find them under oil filtration. someone had about three or four that have been going for a little over 200.
Old Nov 14, 2006 | 07:58 AM
$BANK$rupted's Avatar
Hope that helps
Kevin
The FS2500 is not a full flow filter, it is a bypass filter.
Old Nov 14, 2006 | 01:13 PM
BlackSheep5's Avatar
i know amsoil makes a kit to Relocate stock full-flow filter and adds a bypass filter also.
http://www.amsoil.com/StoreFront/bf.aspx
Old Nov 27, 2006 | 10:40 PM
nickleinonen's Avatar
can't get at the filter from under the truck with twins??? poor design of the twins if that is the case i think. [i don't have twins, but i always change filter from under the truck with flute socket and extension]
Undertaker
Oct 26, 2009 03:02 PM
OH Sick
25
Feb 27, 2007 12:39 PM
pro puller
Oct 23, 2003 08:33 AM
CTD99
Apr 16, 2003 09:13 AM
