recon headlights
Old Jan 1, 2010 | 05:30 PM
Tank_66's Avatar
recon headlights
Good day boys and girls, I got a set of recon smoked headlights for christmas and pulled them out of the box and they look sweet... but no instructions for them... it looks like it has 4 leds on the bottom of the light where does a guy hook them up too, and how hard are the OEM headlights to pull out... its-35C here so I didn't want to play right now...
Old Jan 1, 2010 | 05:40 PM
trksrfun's Avatar
Not sure about your truck but headlights usually come out fairly easily.. I think the hard part will be wiring the new lights, IIRC they are not plug and play but I'm not 100% positive..
Goodluck and post pics when finished!!
Old Jan 1, 2010 | 05:41 PM
Tank_66's Avatar
there is two main plugs so I'm hoping they plug into the original plugs but not too sure about the other wires yet..
Old Jan 2, 2010 | 09:10 AM
Tank_66's Avatar
so noone's every put these on.. now I'm scared, well lets go wreck something tryin to put them on Ill let you know how bad it goes
Old Jan 2, 2010 | 07:26 PM
cbrahs's Avatar
raise the hood, to the inside edge of each headlight there are 2 10mm bolts, on the inner fender behind the headlight, there is a rubber plug, remove that plug and a 6" extension on your 10mm socket and remove that 1 bolt (1 per side), the lights are then held into place by a ball and socket fitting. There will be the need for a plastic piece to pry between the fender and the headlight, then they pop right out. Un plug your OEM headlight and turn signal sockets, install onto Recon lights and reverse order to install.. Post pics when done please.
Old Jan 3, 2010 | 11:29 AM
Tank_66's Avatar
well if i knew how to make my pics smaller i would love to post some
pipeman90
Mar 29, 2011 09:23 AM
IPDiesel
Jan 19, 2011 02:58 AM
MedicShawn
20
Jan 16, 2006 12:16 AM
Rancho71
15
Sep 1, 2005 11:55 PM
Rancho71
Aug 24, 2005 03:13 PM
