Recalibrating Speedometer for larger tires
Go to the dealer, they plug in the DRB and change rev's per mile. 315's are anywhere from 605-615rpm depending on their true outside diameter if I remember correctly. Put a tape-measure around a fully inflated tire and measure how big it is, then divide 5,252 by that #, and that's your revs per mile (I think). If they can't find it, I don't remember all the menu screens but it was under ABS
You can also take a tape and measure the true loaded height of the rear tire (on the truck) multiply it by 3.1416 then divide by 5252. Compare John's Revs to my Revs and split the difference. That will account for a little "tire standup" if you drive like a Tire Hater.
Where did you get 5252 John?
I need to find a dealer around here who isn't a super-<EDIT> about changing the computer. So far they tell me "we can only set it to factory sizes, and it will cost you $89.95". <EDIT>. I'll do the 13% calc in my head
Reported Post Edited By Moderator
TCR,
You stated that the recalibration made quite a difference, what do you mean. I do see my shift points being higher than stock with the 315s, not by the odometer but actual MPH. What improvements did you see?
The revs per mile can only be changed with a DRB. Any repair facility with a DRB can change it for you, but you will probably have a hard time finding one other than at the dealer (spendy units). Most mom-and-pop shops just have code readers or basic OBDII diagnostic tools.
Most all manufacturers give the revs per mile for their tires on their web site. I used 601 for my 315s as well per The Tire Rack web site and it is dead on accurate at all speeds against my GPS.
The dealer can change it in the parking lot with their DRBIII. Under the "Anti-Lock Brake" section, select "Pinion Factor", select "Other" (as your tire size will not be listed), manually enter revs per mile that you want (you will need to know this before you go as the dealer probably won't), save and exit. Total time on the clock is about 3 minutes.....but you will probably get stiffed for an hour labor.
You will want a GPS or a buddy to drive along side of you to check their work. For some reason most dealers have a hard time "saving" the changes and it takes two visits to get-r-done correctly.
If I remember right, my trans shifted a little early after putting on 315s until I had my speedo redone.
On a side note, if you use one of the downloaders (BullyDog for example), this is a section of the ECM that is not messed with, so your speedo recalibration won't be lost. (common question)
You will want a GPS or a buddy to drive along side of you to check their work. For some reason most dealers have a hard time "saving" the changes and it takes two visits to get-r-done correctly.If I remember right, my trans shifted a little early after putting on 315s until I had my speedo redone.
The shift points "seem" to be a little higher in the rpm range, what I mean is it seems to shift a little harder and at a higher rpm. I knew the speedo and milage were off by about 10% but I didn't realize the how bad that was until the change. The tranny also hunts alot less in and out of OD. I dont know exactly what electronic changes actually occur in the recalibration, but I would for sure do it again and recommend others to get it done.
