Ready to install Evil Twin's, but.......
Old Sep 12, 2009 | 06:26 PM
nrussell's Avatar
I need to know if anyone has the ATS intake horn WITH their Evil Twin CP3 kit? I put the cp3 motor mount bracket on and temporarily installed top cp3, and hardline interfere's with ATS intake horn enough that it will not work. Any suggestions??
Thanks
Old Sep 12, 2009 | 07:48 PM
lmills's Avatar
Most cast style aftermarket intake horns (ats, banks, afe, etc)will not work with the cummins pump kits, regardless of manufacturer. The reason is with the way the line comes out of the back of the pump, it is hard to make the turn away from it without having issues with making the turn too tight and compromising the strength of the line.
Old Sep 12, 2009 | 09:28 PM
nrussell's Avatar
can i remove the heater grid? can i bolt the ats intake horn directly to the intake plenum? if so i would be golden.
Old Sep 12, 2009 | 09:33 PM
lmills's Avatar
You would have to check to see if the intake horn is going to interfere with the number 1 injector line. The grid heater has a recess in it to allow clearance.
Old Sep 12, 2009 | 09:50 PM
nrussell's Avatar
it looks like i will have plenty of room if i removed heater grid. other than that, I would be good with removing heater grid? no ill effects?
Old Sep 12, 2009 | 10:01 PM
lmills's Avatar
no ill effects.
Old Sep 12, 2009 | 10:36 PM
nrussell's Avatar
Hey Lloyd
I sent you some pic's via email. would you check them out and let me know what you think?
dfseidel
Jul 5, 2009 10:51 AM
mudder500
Jan 18, 2009 07:55 PM
mudder500
Jan 8, 2009 11:11 AM
dfseidel
26
Jul 29, 2008 07:25 PM
lmills
108
Jul 18, 2008 11:30 PM
