rail preasure question?
at crusing speed my rail preasure use to be about 12.5k, now it is only about 8k. It I step on it the rail preasure dips to about 4.5k then come back up. could this preasure problem be, because of the cold temps well it is 9 out side? or could it be a fuel filter plugging up?
thank you,
Justin Allan
thank you,
Justin Allan
I don't see what brand of rail pressure gauge you have, but when I had my Dipricol gauge it would act as your describing. It would act as if it had a mind of its own when it was cold.
truck is not as reasponcive as it use to be but not sure if it is the cold weather or not. Lack of rail preasure could also cause this as well. When you say reflash unload and reload the smarty program.
you might want to put it on a scanner and go for a ride. Your ecm may be commanding say 16k of pressure when it is only making 8k. It could also show your rail pressure is fine and the gauge is faulty. is your check engine light on?
