Quick Wiring ?
Old Aug 4, 2006 | 05:45 PM
tdm's Avatar
tdm
Quick Wiring ?
Hey guys,
I've just picked up my new 06 3500 with the cummins and 6 speed. This truck will be built up to a reasonable level for towing (450HP or so).
I'm starting to do the pre install bench work on my gauge package and came up with a question:
Is there any reason why I can't combine my Pyro ground wire with my three Light grounds under the pod?? This way I would only have 1 ground wire leaving the pod.
Thanks,
Tyler
Old Aug 4, 2006 | 08:40 PM
WUnderwood's Avatar
I dont see why not. Just make sure it is a good one, and use it for all your gauge grounds.
Old Aug 4, 2006 | 08:51 PM
gerry's Avatar
I soldered all of my ground wire to (1) eyelet and bolted it to the E-brake bracket...
Old Aug 6, 2006 | 01:51 PM
tweeter's Avatar
No reason you can't, you can also do the same for the power side, lights, guages all to one key on source, makes a nice clean install.
HorseHauler
13
Mar 12, 2006 11:48 AM
xp8103
Feb 6, 2006 06:53 PM
caleb c.
May 27, 2005 08:19 AM
RACER47
Dec 13, 2003 12:57 AM
