Quick Dyno Question
Old Feb 27, 2009 | 10:05 PM
sentzible's Avatar
Quick Dyno Question
I've tried searching with no luck. I may be putting my truck on the dyno tomorrow if the shop allowes me to and I was wondering what gear ya'll reccomend I should run in? I've got an 05 with a NV5600 6-speed and 4.10's. I'll also be running the Bully Dog PMT on crazy larry.
Thanks Ed
Old Feb 27, 2009 | 11:22 PM
gus's 03's Avatar
generaly trucks get run in direct , 5th gear in your case. this cuts down on hp loss by not having to turn more gears etc in the trans etc.. .
if you had a large turbo , then it is some times run in 6th to load it harder in an effort to build more boost..
Old Feb 28, 2009 | 08:22 AM
Floor It's Avatar
What type of dyno are you running on? A dyno-jet then you would run in 6th, a load dyno then 5th.
John
Old Feb 28, 2009 | 11:39 AM
sentzible's Avatar
Thanks for the help. I went there this morning and he told me he didn't want to put all that weight on his dyno. So I might try another Dyno on Friday. I guess depening on what kind of dyno i'll be running either 5th or 6th.
Thanks Ed
Old Feb 28, 2009 | 01:31 PM
mulisha's Avatar
how much weight can there possibly be on the rear roller's.the bed of the truck an so on.
Old Feb 28, 2009 | 05:38 PM
sentzible's Avatar
I've got the back of my truck fully loaded with tools. The truck weights alittle over 8500 lbs.
John_P
NCDTR #18
55
Apr 12, 2008 03:56 PM
Dean Snow
Nov 8, 2007 03:26 PM
pwerwagn
Feb 28, 2007 03:18 AM
HorseHauler
13
Mar 12, 2006 11:48 AM
502502
23
Nov 23, 2005 06:16 PM
