Questions before purchasing Smarty
Old Feb 2, 2009 | 09:27 PM
Smokkin's Avatar
Alright I've decided to go for the smarty and not look back, but a few questions I have are if I were to go with the TNT with a few more mods (Fuel system turbo descent size sticks) that will be soon on the way, can I tow on the lowest setting? is that safe or should I just stick with the REVO. The most I would be towing is around 5,500 lbs. Would be EGT's go through the roof? I just wanna be able to play with the TNT but tow on the weekends to the races. Thanks for the input, once I decide this I'm gonna get one on the way.
Old Feb 2, 2009 | 09:33 PM
trx's Avatar
trx
I tow with the TNT on level 5 all the time no problem at all. Egt's are good but if you add stix's you may need to go down a level.
Old Feb 2, 2009 | 10:02 PM
trksrfun's Avatar
its hard to say, going with the bigger sticks will cause higher EGTs but since you said you would go with a bigger turbo you might be alright... it just depends on what size sticks/turbo you run on how well it will do
Old Feb 2, 2009 | 10:13 PM
Smokkin's Avatar
For sticks i'm thinkin somewhere in the ddp 50 or 90 hp ranges and as for the turbo im still unsure i want something that will keep things cool spool relatively quick and get respectable power, im not tying to crunch out dyno numbers or anything just a reliable fair running daily driver
Old Feb 3, 2009 | 09:01 AM
soulezoo's Avatar
DTR 1st Sergeant
Then s300's in the 62mm inducer range will be just fine, or Garrett stage 3 gt3788 for faster spool/same air if you go th 50-75hp stick route. With 90's, you have a lot of power potential that puts you into running small twins (stock over s400, or BD tow twins work well here), 64 or 66mm inducer s300 turbos or garrett gt4094r.
jlsdcen2
Oct 7, 2011 04:16 PM
AVProPres
31
May 28, 2010 05:53 AM
jp39bfd
Mar 26, 2006 06:42 PM
j
Mar 12, 2004 05:26 PM
Beercamel
Mar 6, 2004 07:04 AM
