Question for electrical gurus
Old Jul 5, 2007 | 06:23 PM
own1bigtruck's Avatar
Got an issue I need help with. I have 4- 150watt KC style lights that are getting mounted. With the lights came two wiring harnesses with 50 amp relays. We wanted to power up all 4 with one switch. Question is, can you run the switch lead from both relays to the same switch to get all 4 to come on, or are we going to have to put another 50 amp relay in there to power up the other two relays off one switch? I know this sounds retarded and I should know the answer. We are just trying to do this install right without burning a truck to the ground!
Old Jul 5, 2007 | 06:26 PM
Jays98dodge's Avatar
One switch is all you need. Use both relays!
Old Jul 5, 2007 | 06:27 PM
rmjim's Avatar
sure just hook up the one switch u'll be fine the relays only draw milliamps (very little power)
Old Jul 5, 2007 | 08:16 PM
phabib's Avatar
150W X 4 lamps = 600W. 600W/12V = 50A. That relay can handle all 4 lamps, barely. The advice to run two relays with one switch is sounds, it will make the relays last much longer.
Mexstan
Dec 12, 2016 04:42 PM
rockcrawler304
Jul 7, 2012 09:08 PM
nymegacab
Jun 11, 2007 02:50 PM
spitfire9137
Dec 1, 2005 06:38 PM
scottrod
Dec 14, 2002 09:03 PM
