Quadzilla Commander Install Question
Old Mar 18, 2007 | 06:31 PM
American's Avatar
I drilled the exhaust manifold with a 21/64 drill bit as the directions state but there is NO way a 1/8-27 tap is going to come close to fitting in that hole. Every chart I have says you should use a 21/32 drill...which of course I don't have.
So before I really make a mess of things, who has done this install before and what size bit did you use?
Old Mar 18, 2007 | 06:36 PM
53 willys's Avatar
my chart says Drill size "R" for a 1/8 NPT
but you probably don't have that size ether
Old Mar 18, 2007 | 06:40 PM
American's Avatar
Nope... the thing is that I don't see anyone complaining about this in posts here or on other forums. I've checked my tap about a dozen times...it's stamped 1/8-27...unless it's wrong. Of course I choose to do this on a Sunday...
Old Mar 18, 2007 | 06:41 PM
American's Avatar
1/8" NPT -------------- 21/32"
http://members.aol.com/pullingtractor/taps.htm
Unless I'm reading something wrong.
53 willys's Avatar
have you ever taped anything before???
Old Mar 18, 2007 | 06:44 PM
American's Avatar
I prefer duct tape ...
About a million times... ran an engine shop for 10 years. But I will confess to not memorizing drill size to tap combos.
A 1/8-27 won't even come close to starting in the hole.
Old Mar 18, 2007 | 06:48 PM
53 willys's Avatar
I just check it with a micrometer you need drill size 21/64.....21/32 is way to big!!
21/64 is just a hair smaller then drill size "R"
remember do not tap it all the way through you need the tapper of the NPT to make it thread in there tight and if you go all the way in it may never tighten up
Old Mar 18, 2007 | 06:54 PM
53 willys's Avatar
here is a tap chart that is correct ....
http://www.engineersedge.com/tap_drill_chart.htm
Old Mar 18, 2007 | 07:33 PM
Luvnacumns's Avatar
I used a 5/16 Drill Bit..??? 1/8 Tap worked great!!!
Shane
Old Mar 18, 2007 | 07:37 PM
ptgarcia's Avatar
I used whatever Quads directions said and it worked perfectly. Double check your tap size.
Old Mar 18, 2007 | 07:46 PM
American's Avatar
This tap MUST be mis-marked... guess it will have to wait until tomorrow.
Thanks guys...
Old Mar 18, 2007 | 08:15 PM
imaybail's Avatar
Instructions from Quadzilla Commander say 21/64ths drill size for 1/8-27 or 1/8 NPT tap. It worked for me.
Old Mar 18, 2007 | 10:28 PM
tslewisz's Avatar
I followed Quad's instructions and it worked fine. Pretty sure I wore that bit out 'cause I'm a ham-fisted idiot and didn't use any oil or such basic machinist-type techniques!
Old Mar 19, 2007 | 11:28 AM
Lost Lake's Avatar
Did you ever get this thing tapped? I used 21/64" also, and it worked perfectly.
Old Mar 22, 2007 | 12:35 PM
JThiessen's Avatar
Yeah, I was wondering if he got it also. Just goes to show you what kind of mis-info you can find on the web. Quads instructions were correct (21/64, NOT 21/32).
Did I interpret correctly that he actually drilled it to 21/32? If so, he needs to drill it out to a 23/32, buy a 1/2-14 NPT Tap and tap it to that. And go to HomeDepot and get a 1/2-14 to 1/8-27 (or 1/4-18) adapter.
norcaljr
13
Aug 5, 2008 10:13 AM
JHew84
Mar 5, 2008 12:32 AM
budbon
15
Aug 6, 2007 05:27 PM
stock03
Nov 9, 2006 11:27 PM
edtyler
Oct 12, 2006 03:09 AM
