Quadzilla Commander going crazy
Old Mar 27, 2008 | 06:19 AM
LFD2037's Avatar
I made sure I had it programmed for the correct year. @ idle the tranny temp will go from 115 to 125 in less than 2 sec. & the EGT will go from 385 to 425 in less than 2 sec.. Then when I parked this morning tranny temp. went from 125 to 100 in less than a sec. & EGT's went from 365 to 1350 in less than a sec. for 3 sec. then down to 350 in less than 1 sec.. What do ya'll think the deal is?
Old Mar 27, 2008 | 06:24 AM
Hunter11's Avatar
Mine did the same thing once with the water temp. I found a bad connection under the hood at the sending unit. No problems since then.
Old Mar 27, 2008 | 09:42 AM
welndmn's Avatar
Check your grounds.
Old Mar 27, 2008 | 10:11 AM
LFD2037's Avatar
I thought about that but I doubt they both would go bad @ the exact same time. I'm gonna check the ground(s) when I get a chance.
Old Mar 27, 2008 | 10:32 AM
qzilla's Avatar
Ground is dropping out somewhere. I would start there.
Old Mar 27, 2008 | 11:06 AM
LFD2037's Avatar
Thank you! I'll get back if I can't figure it out.
Old Mar 27, 2008 | 04:25 PM
LFD2037's Avatar
Ground is good, hot is good. Any other ideas? It has done this about 3 or 4 times over the last few months.
Old Mar 27, 2008 | 09:21 PM
LFD2037's Avatar
Anyone else ever have this issue? TIA
norcaljr
13
Aug 5, 2008 10:13 AM
rodsram
Jan 10, 2008 07:55 PM
stock03
Nov 9, 2006 11:27 PM
Atlantic4x4
Sep 8, 2006 09:20 AM
