Quad, will it stack?
Hey Quad, the monitor is supposed to control other modules than yours right? Will it be able to control an adjustable Xzillaraider and say an Edge EZ? Good luck finding some plastic for those things. I see alot of sales just off of this site.
You wouldn't want to stack those two. They're both pressure boxes.
For your truck a good stack would be a VA C3.2. It's a duration box, which will work well with your pressure/timing box.
As far as controlling both, I'll defer to Quad.
Could it be set up to switch between the two? With the Xzillaraider and Xzt you just have to turn the truck off and switch which box is plugged in what.
We have plenty of enclosures. We are trying to finish the first stage of beta testing right now. Our main hold up is the USB stuff and making it easy to update.
Quad
It will also control and de-fuel this stack.
It can also do these two at the same time, but you will need a wiring harness for both.
You can control the modules individually. You will select a primary and a secondary module. The primary module will use the standard up and down buttons to change power levels. To change the power level of the other module you will be required to hold the enter key will you go up or down. It will display the power levels of both modules that are connected.
Now to de-fuel you have different options. Lets say you have the VA and Xzillaraider stacked. You can set it to defuel either the primary or secondary module first, or alternate defueling. Alternating is when it turns the first module down some then the secondary down some and it will go back and forth. The last thing you can do is turn them down simultaneously.
I have not went through every stack........yet. I will and I am working on it, but that is what the usb updates are for.
Here are the boxes that are currently being controlled that work on the Dodge trucks.
XZillaraider
Stealth Module
Edge Juice
Edge EZ
TST
Van Aaken
MP-8
Ramifier
Bullydog torque dog (requires modification to the module)
6 Gun
Now to stack them and control them there are some minor limitations. We only have so many control lines. We could have as many as we want, but the wiring harness would be a rats nest! You can't control a TST and the JUICE. You can control the TST and EZ, TST and VA. You can also control the Juice and EZ. Xzillaraider and VA, XZillaraider and Juice, XZillaraider and TST.
The list will probably look like this:
List A:
Xzillaraider
EZ
Bullydog
Stealth Module
List B:
Juice
TST
Ramifier
MP-8
6Gun
Van Aaken
You will be able to use any off list A and combine it with any on list B. When it is all finished there may be more options, but these are currently working.
Also just FYI, it looks like first release it will only control the Xzillaraider modules. It also works stand alone. There will be FREE updates as we release the software to control addition modules. SOme modules like the TST and Juice and others require some additional hardware to control them. This won't be real expensive, but it is not included with the standard gauge. All of the List A: modules will work with the standard gauge.
If we do not do releases one at a time it will create a nightmare on our end, there is so much it will do.
Also did I mention data logging will be an option?
Can you mix those listed on A? I thought it would be nice to have a pressure box that can be adjusted for towing, along with a high power box for not so towing. Would I have to order the wiring harness for that specific stack? Any idea of what those will retail for. (I would be wholesale of course)
You will be able to mix the boxes on List A. The boxes on List B just take more lines to control them. So depending on what you want to stack we will be able to tell you what you need. There will be some wiring harnesses that are needed, but they will be to interface to a specific module. These are not big harnesses, just small cables.
I know that retail on the basic gauge is expected to be $399, but we have not finalized it yet. I am not yet sure of the cost of any upgrades. We are working hard so it is very in-expensive.
Dodgezilla,
It is somewhat of a maze at times! This is primarily the reason we are going to release them one at a time. That is also the beauty of the USB part. You can buy the first one and then as soon as the updates are ready for the next release all you have to do is download it and flash it if you want.
I heard a rumor that some pictures and info of the real product should be out in the next week or so. I cannot quantify those rumors, but you might want to keep an eye peeled as you will start to see some new info!
Quad
Dodgezilla,
Quad
Plastics appear to be good to go at this point.
Making the USB do exactly what we want is fighting us, but it is just a matter of time before it is done.
Backorderd are the biggest issue we are working on right now.
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
