put the puck back on?
so I am overly paranoid about toasting another set of injectors, seeing as most people think it was the puck and predator (mostly the puck seeing as that was adding all the pressure). seeing that I have the new Flux 1's, do you think the puck is safe to go back on? I have been running the predator on the Econ setting and just keepin it easy, but from what I hear these things are pretty hardcore, and should be able to take a lot of pressure right?
really?! man, I can tell a difference when it is on, although just before i took it off, I couldnt, and then I went to set everything back to stock, and it said that the puck was already on stock....so that would have explained that.
maybe that was what happened to you?
barngal6
Jul 5, 2009 06:49 PM
BIGDAN65
16
Jan 23, 2008 10:02 PM
JoshPeters
Apr 3, 2005 08:13 AM
2500TurboDodge
Jun 2, 2004 08:21 PM
