prxb hissing.....
prxb hissing.....
Just got my brake put in yesterday, not to bad to put in. I have a horrible hissing noise when the truck is at idle and the brake in on. When I am up to speed I dont hear the hissing tho, Im thinking leak on the turbo to brake flange, but cant really tell, I will take apart when I get home on the weekend and check. My Cat is missing and I have an aeroturbine muffler with the stock resignator still in.
Anybody else have this happen??
thanks
thanks
When the engine is cold and at idle, it will make a hissing sound. Having a non-resonated muffler like an Aeroturbine will make this sound pronounced. Once the truck reaches 170 degrees, it should stop engaging at idle and the truck should sound normal.
The hissing comes from the exhaust having to flow through the small orifice in the butterfly on the PRXB. Completely normal.
If there's a hiss coming out at operating temp, then I would search for an exhaust leak. Seeing that you have a Smarty, it shouldn't be hard to find soot if there's a leak...
Ha Ha I found it, there is a leak between the exhaust manifold and the turbo housing, only when the brake is on. Thats my crazy hissing noise.......
P.J
04-16-2007 07:54 PM
ptgarcia
41
03-06-2007 06:56 PM
ptgarcia
02-07-2007 12:34 PM
Thundercloud
11-22-2006 09:47 PM
