Programmer Question???
Old Mar 1, 2006 | 09:28 PM
WSA308's Avatar
Question Programmer Question???
I have an 04.5 3500 CTD but just recently realized that the used programmer (Bully Dog Power Pup) that I have installed is for 03-04.5 and the 04.5+ is a different part number. I have had this programmer installed for some time and it seems to make great power. Are there any known or potential issues that may occur from using what may be the incorrect programmer?
Is it possible to load an incorrect programmer?
Also just wondering if anyone has had any experience with TCI torque converters and performance transmissions?
Old Mar 2, 2006 | 08:48 PM
horsepoor68's Avatar
From what i understand the power pup does not work on the standard only auto. Lots of info on 3rd gen performance threds.
Old Apr 30, 2006 | 05:09 PM
WSA308's Avatar
Where in my post does it indicate that I was asking if it works on a standard?
I need to find out if I will be causing any issues using a BDPP for an 04 VS 04.5....I'm guessing that yes there quite likley will be some issues but would like to know for sure before I look at getting something else like the edge hot juice with Attitude.
Old Apr 30, 2006 | 11:06 PM
lightening ram's Avatar
i dont think it matters, if it did explain why the tripple dog works from 03-06 trucks, only difference is that i think it will load a different ecm number like from the older trucks, does it start differently, run differently, harder or easier on fuel, do you hear any more rattle under your hood when driving?
Old May 1, 2006 | 02:03 PM
WSA308's Avatar
Not sure there was any diference, just noted the BDPP for 04.5 has a diferent part number than the one for 04. Was just curious if anyone knew why thats all.
Old May 1, 2006 | 02:17 PM
ramtradxb's Avatar
Beware - I have 06 and so far, none of the aftermarket programmers work on it. C-D changed the computer in some 06's, and it uses a totally different language that the aftermarket folks haven't adapted yet. Hook a programmer up and it doesn't hurt anything - but doesn't change anything either...
Old May 1, 2006 | 05:34 PM
coobie's Avatar
Do a search,if I remember correctly there was a long thread on this issue causing someones ECM to take a dump. coobie
Old May 1, 2006 | 05:48 PM
texaspower19's Avatar
the triple dog works fine on my 06, but yours might be a later model
Old May 1, 2006 | 08:54 PM
Nitro71455's Avatar
I have an 06 that was made in 2/06. Tripple Dog works just fine on it.
Old May 1, 2006 | 09:41 PM
just got mine 2 weeks ago also and the tripple dog works awesome also.
mstordahl
Oct 21, 2007 10:13 PM
yellowhemi
15
Jul 5, 2007 09:57 AM
mudder500
May 30, 2007 03:34 PM
CmminsBeast
Jan 20, 2007 03:15 AM
lowboy18011
Feb 20, 2006 03:22 PM
