Programmer module question
Old Jan 18, 2007 | 07:21 PM
CmminsBeast's Avatar
I know this is a endless subject thats asked all the time.
But, these are all new to me and don't know some of the brands by the names used.
Can someone give some pros/cons between the 2 types, and the company names and models?
Pushing my luck here, but how about some of the differences between brands? I just read something about the edge don't adjust fuel pressure but some other brand did.
Would be nice if someone could make a sticky of some sort that answers some of these questions, might keep the question from popping up so much.
Old Jan 19, 2007 | 02:08 PM
forced5's Avatar
For your 04 I would assume?
Old Jan 19, 2007 | 02:36 PM
KBennett's Avatar
When I was shopping the two choices it came down to for me was the Edge Juice and the TST.
Edge Juice: Nice smooth adjustable power up to 100 HP with the Attitude. Another cool thing with the Attitude is that you can put limits on EGT's and trans slippage and it will automatically defuel.
TST: Not as smooth but has much more potential if you eventually upgrade the turbo, fuel system, etc.
The Edge Hot Juice and Edge EZ will raise rail pressure, but the standard Juice does not. I don't know if the TST raises pressure.
The other performance option is the Smarty. I have heard a lot of good things about it but I went with the Edge because it is adjustable on the fly. The Smarty is a downloader so it takes a few minutes to change programs.
There are more but these are the ones I have some experience with.
Old Jan 19, 2007 | 02:58 PM
forced5's Avatar
I have a Edge W/ Attitude, and love it.. It is perfect for me as I do not need that much power like upgraded turbo's and such, but it will definitely make enough power to kill some of the weak links in your truck if you get carried away with it..
BTW Bennett: I did not think the Juice W/ Attitude added pressure.. I thought it was duration and timing..
Old Jan 19, 2007 | 03:12 PM
KBennett's Avatar
You are correct. The Hot Juice increases pressure, the standard Juice does not. I added punctuation to my post so that it is more clear.
Maybe there should be a sticky with all of the boxes, downloaders, etc. listed so that there is one place for reference.
Old Jan 19, 2007 | 03:16 PM
forced5's Avatar
Yes, I think that would be a good idea for those out the.. with a list of features and pros and cons..
Old Jan 19, 2007 | 06:30 PM
Yes for my 04 Ram. Anyone tried the A2?
Old Jan 20, 2007 | 03:15 AM
973604x4's Avatar
Hot Juice does not add pressure on 04.5+ trucks...atleast thats my understanding from Edge.
Yes had an A2. Had problems with it freezing up and not working for days at a time. Edge bought it back cause they knew they didn't have a way to fix it at the time. That was almost a year ago now so surely they have it figured it. when it worked, it was a very neat toy to have!
john.overton
Nov 15, 2007 12:16 PM
j
Aug 10, 2007 04:22 PM
ramtd02
Nov 18, 2006 04:40 PM
lowboy18011
Feb 20, 2006 03:22 PM
jlells01
Oct 18, 2004 06:50 PM
