Problems with Dr. Performance 2021 Module
Old Jun 27, 2007 | 03:36 PM
CReed's Avatar
I am running the Dr. Performance 2021 module on my 07 5.9L and i have recently started to experience when i stack it with my diablo and really get in it, the P0148 code will be thrown which is a Fuel Delivery error. Anyone else experiencing this i talked to dr. performance after about 30 calls today and only cusing at the audimated answering machine and leaving several messages I finally got a person to answer and not a dang audimated machine. Their solution was sending the module back and reflashing it(remember it is on 3 months old) and by them reflashing it the module will still set the code but it will be cleared by flicking the module to tow mode then back to performance again after a hard pass. . Does this sound silly to anyone else or just me? Any body seeing these problems?
Old Jun 27, 2007 | 03:48 PM
06CTDforAU's Avatar
If you ask me, it is the Diablo setting off the code not the Dr. P module. I have experienced that same code as well as several other guys I know while running the Diablo Predator. Diablo says we are having fuel delivery issues and that it is not their programmer. I can understand the fuel supply issues, but not on the tow/economy setting.
Old Jun 27, 2007 | 03:54 PM
CReed's Avatar
No it did it on the first truck it came off of by itself dealer said its a fuel system error change filter and so did dr. performance well we put it on my truck and i bought him a diablo and his truck hasnt done it since but the box keeps throwing codes on my truck so i talked to dr. performance and they stated that it was the box and then gave me some off the wall #s that i didnt comprehend and im not sure it the guy chattering them off did either.
Old Jun 27, 2007 | 04:19 PM
06CTDforAU's Avatar
Lol. Yeah I love how the techs act like they know everything. I'm not sure then on your codes. I just know that my Predator threw that same code in my truck as well as two other trucks. Took it off and haven't had the code since.
Old Jun 27, 2007 | 07:06 PM
TXGREYGHOST's Avatar
CReed,
Dr Performance will take care of you, don't give up. If you need I can make a call I used to own a company that was a distubuter for Dr Perfomance, they have great dealer support, so if need anything let me know, I'm in Humble, Tx. On a side note do you know Josh Danner?
Old Jun 27, 2007 | 08:57 PM
CReed's Avatar
Nope who is josh danner am i suppose to know him from around my area or what?
Old Jun 27, 2007 | 09:05 PM
CReed's Avatar
Ok so apparently all 2021 modules from Dr. Performance are defaulted to the performance option which is usually the level that sets the code. Dr. performance tech told me this afternoon send it in and they will default it to the tow option. Not a clue what any of these means and when i asked him he gave me some more gebirish just like the last tech i talked to this morning. TxGreyGhost I may take you up on that offer i cant seem to get the same answer over the phone each person i talk to says something different. Maybe you can get ahold or put me in contact with the right guy at Dr. P my buddies distributor is going to call dr. p tommorow for us hopefully he will have good news for me. As of right now no matter what they do I dont want to see this code again due to the module and from what they have told me all they can do is rearange some stuff and this will allow me to clear it with just toggle switch instead of having to bust out the downloader everytime that gets annoying everytime you get into it. Their other option they gave me was to drive around with the check engine light on. LOL. All i want is the box fixed with no check engines light every time i get into it.
Old Jun 27, 2007 | 09:17 PM
CReed's Avatar
TXGREYRIG Josh Danner he owns that Navy Blue 01 truck with the 38s and works at the Cleveland Mack Truck Place?
Old Jun 27, 2007 | 09:56 PM
Yeah that's him, he's from Cleveland, just thought you might know him, or atleast the truck
Old Jun 27, 2007 | 10:08 PM
CReed's Avatar
Ya I know the truck ive see it all the time I think Ive meet him before but not sure. What all is on that truck? If you dont mind you got any Dr. P #s for me to try or would you mind talking to your guy and have him call me if I PM you my #.
Old Jun 27, 2007 | 10:24 PM
I don't have the numbers on hand but I can get you the numbers, the head guy in charge in is a guy by the name of Cater, can't think of his last name. i'm not sure what is on that truck performance wise. It has a Skyjaker long arm lift 38 mtz's with 20x10 mazzi hulks.
Old Jun 27, 2007 | 10:33 PM
cummins dsl's Avatar
Do you have any aftermarket fuel pump mods? If not you are demanding a lot of to be supplied through the stock set up. If you are running the stock set up I would recommend looking to into a GDP, FASS or what ever suits your needs. But that code means you are not suppling the fuel demanded and the truck is setting a delivery error code because the supply is not meeting what is demanded.
Old Jun 27, 2007 | 10:39 PM
CReed's Avatar
Im pretty sure that the rail pressure isnt falling off buddy has similar setup and maintains 25k psi easy i will be adding a GDP to the truck when I do Injectors but not doing that for awhile gotta save up for tranny, etc. But I do see what you mean and the Dr. P techs didnt seem concerned about the pressures believe me i asked if this could cause this problem.
Old Jun 28, 2007 | 01:09 PM
I wasn't refering to your rail pressure dropping. I was refering to your stock lift pump suppling 8-10 psi max and you are stacking to different power adders which just one of them alone is probably capable of running you down to 0-2 psi. Which would mean the truck is not getting what it desires and can cause a fuel delivery error. Just trying to help from what I have seen on many trucks and what I have seen make a difference.
Old Jun 28, 2007 | 01:26 PM
CG98x's Avatar
I agree with cummins dsl the lack of fuel at the CP3 will cause that code. I got it when the relay for my FASS messed up and it didn't run.
