Pricol Rail Pressure Gauge
Can I use this gauge with any module that plugs into the rail sensor? I guess the Pricol wiring harness plugs into the rail sensor and the module plugs into the Pricol harness. Is that correct?
Is the Pricol Fuel Rail Gauge competely electronic (ie, no fuel in the cab)? Where can I buy one of these gauges at and how much do they run? Also, what kind of lift pump gauge are y'all running? Do they make lift pump gauges that are completely electronic (ie, no fuel in the cab)?
There is no fuel in the cab. The rail pressure sensor is on the rail on the engine. It is electrical and measures usually around 5000 PSI at idle and up to 29000 PSI, plus or minus, at WOT depending on mods, etc.
You can buy the rail pressure gauge just about anywhere they sell gauges now.
Autometer is about the only electric fuel pressure gauge on the market now. The Phantom series has white face gauges that match our trucks very well in the day but not the best at night.
Most use FASS or Walbro fuel pumps. FASS can be bought at most performance shops and the Walbro is best had from http://www.glacierdieselpower.com/
There some electric solutions in the form of monitors on the market now. Quadzilla and Edge come to mind. You can buy most of Quads stuff right here on DTR.
Franklin
Sep 2, 2008 08:48 AM
sallyman1
39
Feb 29, 2008 01:14 AM
wyocat
Dec 17, 2007 04:17 PM
zkhoss
Apr 26, 2005 11:46 AM
ATEAV8GN
Dec 13, 2002 08:51 AM
