Pressure
Old Mar 27, 2008 | 10:47 AM
  #46
omaharam's Avatar
Originally Posted by Justice4all
The fuel is metered as it enters the pump by the FCA, and rail pressure is read in the rail through the rail pressure sensor. The ECM reads rail pressure and controls the amount of fuel metered by the FCA, therefore despite the pump's capability to flow the ecm can control the amount of fuel pressure in the rail by metering the amount of fuel flowing through the pump. That is why when you plug a pressure box into the rail sensor it is able to alter the RP signal to command more fuel from the FCA.
The RV really has no effect until rail pressure has exceeded the maximum limit and blows through. At cruising speeds it should remain closed. If not, it leaks and should be replaced.
So where does the extra fuel go that the pump is moving?
Old Mar 27, 2008 | 12:30 PM
  #47
Justice4all's Avatar
Excess fuel is regulated by the cascade overflow valve (COV) in the CP3. According to design the COV has 3 main functions It regulates internal pump lubrication, it regulates fuel pressure supplied to the Fuel Control Actuator and it controls the return of excess fuel to the tank through the return circuit.
Old Mar 27, 2008 | 12:47 PM
  #48
omaharam's Avatar
Ok, so is the return valve and line to the tank able to flow all the extra fuel back no matter the volume that the modded cp3 - or duals - is producing?
Old Mar 27, 2008 | 12:57 PM
  #49
I am not really sure how duals are set up on the return, but in the case of the single CP3 the stock return circuit is adequate.
Old Mar 27, 2008 | 01:49 PM
  #50
jrussell's Avatar
Originally Posted by Kman9090
I said last week cruising at 20K+ pressure will kill an injector at in unreasonable rate and was called a liar?? I guess there was some proof in my statement? At cruising I see anywhere from 15,000-17,500 cruising.
That is complete BS. Go back and re-read the thread. Nobody called you a liar.
Cruising at what speed? The only time I see 17,000 is if I drive 50-60 MPH and we all know how people like to go 55 MPH everywhere they go.
The truth is that guys are seeing 20k cruising on a regular basis with stock pressure programming. I'm pretty sure most guys that have a properly operating CP3 are pushing close to 20,000 at regular highway speeds of 65-75. With close to stock tires and 3:73 gears the engine is turning 2000 RPM at 70 MPH, so most of these trucks are easily at 20K cruising.
If it is truly the case that 20k cruising speeds kill injectors, then we should be on a quest to reduce stock pressure from destroying our injectors.
Well said.
I would also like to know how we're expected to keep injectors alive if our truck cruises 75mph at 20k psi with stock programming? If 20k is too much then Dodge/Cummins screwed up pretty bad.
Old Mar 27, 2008 | 04:41 PM
  #51
Kman9090's Avatar
You pretty much said there was no truth in my statement and that it was pure speculation. Then you said "why listen to somebody that stacks two timing boxes", when you don't know what I run and in what moderations? But it's all right, I don't really care everybody is intitled to thier own oponion.
Old Mar 27, 2008 | 04:55 PM
  #52
jrussell's Avatar
Well it was at the time.
Old Mar 28, 2008 | 11:11 AM
  #53
cquestad's Avatar
NOBODY needs more than 50% of the MP-8...
Monitor your rail pressure...spend the dough for the gauge...its worth every penny for tuning, diagnostics, and just enertainment.
I have run the pressures Don has stated on my 04 for 140k...with NO injector problems.
Old Mar 28, 2008 | 11:43 AM
  #54
tristan21's Avatar
I ran the mp-8 and edge cranked for a few months before I had a brain. Couldve had something to do with the blowin by injectors. I dont recommend it.
Old Sep 5, 2009 | 01:40 PM
  #55
LakeLife79's Avatar
Thank you sir now I know im not alone here. I see 18-20k cruising at 70-75, I dont want to have to drive 55 to keep my RP numbers lower. We need an MP-8 or something similar that can also lower STOCK RP as well as raise it for when you want more. From my experience I have had an 06 and 07 both had RP gauges and they both have high cruising RP numbers stock programming or not. I dont want to have to replace my injectors every year and so far thats what ive been doing.
Old Oct 13, 2009 | 09:52 PM
  #56
krh's Avatar
krh
sorry to bring this one back to life but i didnt see an answer to whether or not complete aftermarket injectors will withstand these higher rail pressures or not. I need to buy injectors this week as my truck is down and that would really help with the decision.
Old Oct 14, 2009 | 06:47 PM
  #57
bradler's Avatar
Originally Posted by tristan21
Just take the bolt out of the top and see if there is fuel in it. Dry it out and start the truck if you get fuel its shot.
Are you saying to start it with that banjo bolt out? Cause i would sure cap that line or else it will flow return fuel from the cp3 all over the place! Remember fuel on top of the valve doesn't mean its failing because the cp3 return line tee's into the return line connecting the relief valve at the fuel filter hosing before routing back to the tank. So in other words fuel from the cp3 return will flow to the top of the relief valve. You would need to dry out the valve and start it with connecting line capped off to see if the valve is actually leaking. The dealer has a fitting just for that...
Old Oct 15, 2009 | 06:04 AM
  #58
homewrecker's Avatar
When I have done this I just gently push the return line to the side of the relief valve and then zip tie a bag on to catch the fuel.It doesn't take but a couple seconds to verify if the RV is leaking or not.
But a special banjo bolt/plug would be nice! Anyone know the Cummins part #?
Old Oct 16, 2009 | 03:27 PM
  #59
bradler's Avatar
yep, done that too, then i found this test fitting from glacier diesel
Old Oct 16, 2009 | 06:04 PM
  #60
Thanks, I had no idea they offered this part.
snakefarmer
Jan 3, 2006 05:29 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
