PPO Mixture ?
PPO Mixture ?
I just purchased the Power Services Diesel Kleen + Cetane Boost. It says on the bottle to mix 32 oz/100 gal for a Cetane Boost of +3 or to mix 32 oz/50 gal for a Cetane Boost of +6. What is working the best for you guys? Thanks in advance!
I myself and a lot of people use the Power Service (grey bottle)12 ounces mixed with 4 ounces of Marval Mystery Oil both found at walmart.
others find success with lucas additive, and also Stanadyne additive both are pricey.
Jamie
Jamie
I use the same Power Service Kleen and Marvel Mystery Oil. 3 parts PS to 1 part MMO. Use 16oz of mix in every fillup(28-30 gallons). Been using this combo for about 15,000 miles now. I am a convert. I believe. Runs quieter and smoother. May help mpg, don't know, but the added lubrication and injector cleaning can not hurt. Cost me about $2.22 a tank. Buy both at Wally-World.
I mix 64oz of power kleen gray bottle to 40 oz of mmo in to a gallon jug. When I fill up, I mix 1oz per gallon of the cocktail to my fuel. This way, no matter how much I fill up, I know exactly how much mixture to add to my tank. I bought a funnel from walmart that has measurements on it. This make it pretty easy at the pump.
4x4 not, half a bottle?!?!
What size bottle are you using?
I'm using the PS+MMO combo. If you have the large PS bottle then all you have to do is buy a new bottle of PS and a bottle of MMO. Split the PS into the two bottles and then split the MMO into the two. Shake and serve
JBradley500
Nov 8, 2010 07:48 PM
Catmandoram
May 20, 2009 11:57 AM
