Powder Coating H2 Rims
Old Oct 3, 2006 | 09:31 AM
CTD23's Avatar
So my buddy has a small little powder coating system i believe from Harbor freight, and i have a spare oven i can use to bake em in... As far as preping them before powder coating anything I should do other than the norm? scuff then acetone? then coat then bake?
just checkin thanks
JC
Old Oct 3, 2006 | 10:41 AM
njmaier's Avatar
I would (if the wheel condition is good):
-strip all paint off
-scuff with 220-320 grip paper
-degrease throughly
-out-gas the wheel in the oven for 25 minutes at 450 degrees (cast parts have pockets in them...this releases any gas or grease)
-degrease again
-coat and cure
Old Oct 3, 2006 | 01:21 PM
CTD23's Avatar
now they are the cast aluminum i beleive they are not the chrome h2's...but is there a light sealing coat of paint on the rims or ...are they acctually painted!?
Old Oct 3, 2006 | 01:38 PM
njmaier's Avatar
With most wheels that I have seen and worked with they usually have a clear coat and some sort of paint or coating already on them. I would just go to Wal-Mart or wherever and get some aircraft paint stripper in the spray can or get the gel-type stripper (from Eastwood Co. or a good auto parts store) that you can paint onto the wheel and let it do the work. Both work well and are not expensive. You must get all the paint and grease off first or the PC will not cure correctly, and it will look like crap.
Old Oct 3, 2006 | 03:25 PM
BossHogg's Avatar
I had mine baked at the pc shop bfore they powder coated. They have a clear coat as mentioned above, but it is powder coated underneat, and pc sticks to pc good. It was much cheaper than stripping them, took less time, and has held up perfectly! Looks great too!
Old Oct 3, 2006 | 04:15 PM
njmaier's Avatar
True...you can PC over PC...just scuff, degrease, and pre-heat
06RAMCTD
Nov 30, 2006 07:26 AM
nchapa
Oct 2, 2006 10:31 PM
Moose10
Jan 8, 2006 06:10 AM
Topper
Aug 10, 2005 12:55 AM
Topper
Jul 20, 2005 09:14 AM
