Pinched off turbo
Old Sep 27, 2007 | 07:10 PM
CLeger67's Avatar
Pinched off turbo
I think this is right, let me know if it's ok or not. I was only making 21 lbs of boost acording to my Bullydog monitor. I know analog is better but...anyway. I tried a boost fooler and I max out at 18lbs. So, I pinched off the tube that goes to the waste gate and am now making 28lbs and I can here it whistle now. I know this isn't the best way to solve this problem, thats why I'm asking. I haven't put the boost fooler back on yet, is it alright to?
Old Sep 27, 2007 | 11:43 PM
bsj04's Avatar
i did the same thing with some vice grips. i think your probably making more boost than you think. stock shoud be about 26psi. when i pinched mine off with the diablo predator on extreme it would get up to 38psi witch is to much for our turbo.
Old Sep 27, 2007 | 11:57 PM
chrleb1's Avatar
The boost fooler doesn't do anything on a 03 or 04. The 04.5 have the electronic controlled wastegates. The 03-04 is a manual wastegate. Basically what you did is what a "boost elbow" does.
Old Sep 28, 2007 | 08:57 AM
CLeger67's Avatar
So it'll be OK to leave it?
Old Sep 28, 2007 | 10:38 AM
chrleb1's Avatar
Yeah, 28 psi is not a lot of boost. I've seen stock turbos go to 45 psi (with hard fueling). The only thing is, 36 psi is the limit of good efficient air on the stock turbo. Anything after that, the discharge air becomes a lot hotter.
Old Sep 28, 2007 | 11:09 AM
kantdrive55's Avatar
DTR Advertiser
You are talking about a wastegate fooler. The boost fooler is something different. It is there to clamp the voltage on the map sensor so that the computer thinks it is making less boost than it really is. The ECM will defuel around 28psi because in stock form the truck shouldnt make more boost than that. The boost fooler clamps it at around 21psi so it will continue to add full fuel and not defuel on high boost.
Old Sep 28, 2007 | 04:33 PM
CLeger67's Avatar
I hooked the boost fooler back up and it only shows 18lbs, digital, no analog, which should be around 24-26 actual. I don't know for sure but it's not nearly as responsive and seems to have lost power plus I no longer hear the turbo whistle. It runs way better without it. Anybody want to buy a nearly new fooler?
Old Sep 28, 2007 | 05:19 PM
chrleb1's Avatar
I've never had an 03 defuel with high boost. I run about 60 psi and I seriously doubt it is backing off without a boost fooler.
Old Sep 28, 2007 | 05:23 PM
stock03's Avatar
Do you know the max efficient boost for a SuperB? Right now I max about 32#.
chrleb1's Avatar
A plug-in boost fooler (in the map sensor), it a waste of money on an 03-04. Just keep the wastegate tubing pinched (this is like a boost elbow).
Old Sep 28, 2007 | 05:30 PM
stock03's Avatar
Follow up question: Can you cut the hose and just install a plug instead of using vise grips?
Old Sep 28, 2007 | 06:44 PM
Caterpillartim's Avatar
stock03>> you stick just about any thing, just stick a bolt in there and clamp it
Old Sep 28, 2007 | 07:17 PM
Mighty Goat's Avatar
I bought the tst elbow... and the quad does my fooling. waiting on the commander to get some readings. but, the elbow helped out. on our turbo, save the 35 bucks and just plug it. if it blows up, just buy a real turbo. that's what i'm gonna do
Old Sep 28, 2007 | 07:25 PM
ModManiac's Avatar
Let me guess the bullydog monitor plugs into your truck somewhere instead of being tapped into the intake elbow?? Thus with the boost fooler and you only seeing 18lbs of boost is the same thing your trucks computer is also. In other words the boost fooler is fooing you and your truck into thinking your seeing 18lbs of boost ...lol
Old Sep 28, 2007 | 09:14 PM
cmnsdsl's Avatar
I went round and round with the stock turbo and couldn't ever get beyond 28-30 PSI with the vice grips and the quad race box. Someone did some work to figure out the efficiency maps for the 2003-2004.5 turbo and if I remember correctly it is very inefficient above 28 and really heats up the intake air temps. If you search you can probably still find the threads.
Now the 2005 turbo is a little more entertaining. I had to block the actuator hose, but that's all the boost foolers do anyway, just using the electronic actuator instead of a mechanical block. I'm good for 36+ now! I don't know why dodge didn't just build them like that in 2003...
