Pics of Jeep Liberty fuel canister (for aftermarket lift pumps)
Old Dec 8, 2007 | 08:13 PM
  #31
53 willys's Avatar
Originally Posted by gmctd
Well, congrats, then - I was hoping it would work as well for y'all as the Dodge lift pump module works in the hereto-fore pumpless Jeep - I think it is a good exchange of technology, this for that, tit for tat, satisfyingly rewarding.
why did you want the Ram factory lift pump in your liberty??? just to help the CP3 last longer??
Old Dec 8, 2007 | 08:20 PM
  #32
cbrahs's Avatar
the Liberty does not have an in tank pump. It is similar to the Dmax system and just draws off the cp3. now he has an in tank pump in the liberty from the dodge ctd and a liberty module in the big truck to cure the 1/4 problem. kind of 2 birds with 1 stone affect. I am thinking of doing this as well with an AirDog and the liberty module.
Old Dec 8, 2007 | 08:50 PM
  #33
53 willys's Avatar
oh-ok I did not realize he had swapped the two I thought he just did the ram canister for his liberty..thanks Chris
Old Dec 8, 2007 | 09:43 PM
  #34
gmctd's Avatar
Exactly - the Jeeps have lots of problems with the fuel manager head - it is mounted high on the firewall, higher even than the engine - all air bubbles in the system collect there, so we have A.) problems with fuel supply if it is not primed and the air bled out, regularly, and B.) the fuel heater self destructs due to being submerged in air, rather than fuel - the Dodge lift pump module cures all that, loading the system with steady 9psi -and we can now enhance the filtration, if so desired, being that the filter is under pressure, rather than vacuum.
Thank you, Dodge boys!!!!!
Old Dec 8, 2007 | 11:14 PM
  #35
5.9Excursion's Avatar
Don't mean to hijack, but I'm hoping someone still has there pickup assembly out of the truck. I'm trying to determine what the resistance range (in Ohms) of the fuel level sensor is? I'm trying to eliminate a code I'm getting in my cummins swap, I need to simulate a "normal" tank level reading to the ECM. Thanks...
Old Dec 8, 2007 | 11:44 PM
  #36
gmctd's Avatar
Up - 20 ohms +/-5% - ~0.6v - FULL
Down - 220 ohms +/-5% - ~7.0v - EMPTY
Best to check for voltage in-circuit while watching fuel guage -
Old Dec 8, 2007 | 11:48 PM
  #37
cbrahs's Avatar
were you sitting on that thing when he posted? That was fast!! WAY TO GO!! Now that is service!
Old Dec 9, 2007 | 12:03 AM
  #38
Awesome, I should be code free by tomorrow!
Thanks...
Old Dec 9, 2007 | 12:11 AM
  #39
Fisherguy's Avatar
Anyone know what the Liberty set up would cost to buy?
Old Dec 9, 2007 | 12:13 AM
  #40
gmctd's Avatar
The Liberty fuel module is ~100bucks at yer local fuel module emporium
BTW and FYI - that fuel guage sender module is merely clipped onto the fuel module - float, arm, element are a self-contained one-piece assembly, easily separated and transferred.
That's it, there on the side
Old Dec 9, 2007 | 01:27 AM
  #41
Spooler's Avatar
Already called the dealer and it's $92, that's it.
Old Dec 12, 2007 | 06:52 PM
  #42
Coolhand37's Avatar
Since I have a 04.5 I'm thinking I would not need to worry about losing fuel at 1/4 with an aftermarket pump and thus not need the jeep fuel module correct?
Old Dec 12, 2007 | 07:00 PM
  #43
Spooler's Avatar
Correct, as long as you haven't had your lift pump replaced with the factory in tank unit. If you have or don't know you should have a sticker stating an alteration to the fuel system on top of the radiator support.
Old Dec 12, 2007 | 07:43 PM
  #44
Coolhand37's Avatar
^^Thanks for clearing that up, I've been reading so many threads about fuel system mods tonight my head hurts.
Old Dec 12, 2007 | 10:12 PM
  #45
realsquash's Avatar
GMCTD, I don't suppose you removed the fuel pump from the sender have you? I'd like to know what the pump itself looks like. I wonder if it's like most other replacement in-tank pumps?
Andy
