? on performance chips and smoke!
Old Aug 10, 2005 | 09:47 AM
Graphite600's Avatar
Does the edge or bully dodge chips provide you with a nice puff of black smoke on start-up? I love the idea of starting my truck and having a huge puff of smoke roll out the pipe!, I saw a second gen. do this the other day and it was sooooo cooool, looked like a big rig! Which chip is the most impressive as far as giving a nice smoke show, and for unbelievable power increases? Edge, Bullydog, Quadzilla, TST?????????????????????????????
Thanks for your help,
RYAN
-getting gauges this week so I need info on these chips, can't wait till I have all that power and smoke!
Old Aug 10, 2005 | 03:49 PM
StrokeThisCTD's Avatar
i had an edge EZ and it didnt smoke much more than stock, if any more.
The BD will roll heavy smoke from 0-40 and then from about 40-105 its still a lot, but just not as much. definitely noticable though
this on 90hp performance setting
Old Aug 10, 2005 | 08:15 PM
With the bully dog, did you get a nice puff of black smoke when you first start the engine?
Old Aug 10, 2005 | 08:51 PM
502502's Avatar
Re: ? on performance chips and smoke!
RYAN
As for the start-up smoke, I think only 2nd gens do it because of the injection system... I have not saw any 3rd gens to it...
Though mine seems to smoke a bit when needed:
http://www.turbodieselregister.com/f...d.php?t=135268
And as for the power, My dyno page says it all aboutt he TST/EZ combo
Old Aug 11, 2005 | 06:24 AM
cschulz's Avatar
The BDDL will not give you smoke at start up up because it does not start adding power until engine temps exceed 140 degrees. I think all the boxes for the newer trucks are similar in that they allow the engine to warm up before giving you full power increases.
Old Aug 11, 2005 | 08:54 PM
mine will give me smoke at idle, not a puff, but just a light smoke. my friends stock 05 610 does that as well though.
if i turn it on, and press the throttle the slightest bit it will puff out a nice amount
here is what happens with the BD on performance giving a little powerbrake
http://www.dodgetrucks.org/home/shauncobb/MOV01813.MPG
http://www.dodgetrucks.org/home/shauncobb/MOV01814.MPG
Old Aug 11, 2005 | 11:36 PM
realsquash's Avatar
That's with the downloader on 90hp???? Mine doesn't do that set to extreme (tri-dog)! It will give a good strong puff, but nothing that lingers in the air like that! Above about 20mph it hardly even hazes!
Andy
Old Aug 11, 2005 | 11:44 PM
AK RAM's Avatar
Originally posted by cschulz
The BDDL .............does not start adding power until engine temps exceed 140 degrees.
Really? I didn't know that. Interesting.
Old Aug 11, 2005 | 11:48 PM
Andy
yes that is 90hp. i dont have the nuts to let Crazy Larry destroy my motor
Old Aug 12, 2005 | 11:45 AM
502502's Avatar
GEEZ!!
Thats some sick low boost fueling, Boy know I know why people stack the TST and the DL'ers
Old Aug 12, 2005 | 02:41 PM
CCOUGHRAN's Avatar
seems to me that the 04.5 smoke more than the 03 555's. i have just the edge ez, and i see a small amount of smoke when the engine is at low boost. what box will have the most smoke effect on my 2003?
thanks, chris
Old Aug 12, 2005 | 03:59 PM
realsquash's Avatar
I could barely get a haze with the EZ on 4 on mine...
Andy
Old Aug 13, 2005 | 02:02 AM
dodgedude361's Avatar
The EZ will NOT smoke...on any level. The EZ is a preasure box. To get smoke you need duration.
Old Aug 13, 2005 | 05:08 AM
DSLRammin's Avatar
100%-VA C3.2 + EZ-4 = insane smoke
Old Aug 13, 2005 | 07:20 AM
mikmaze's Avatar
<<<<< runs to classified to see if there are any va's in there...........
