Performance cam installer in Houston, San Antonio or Austin
Old Jun 10, 2006 | 11:28 AM
PowerDually's Avatar
Does anybody out there in the houston area, san antonio area or austin area know of a reputable shop or individual that can do a cam install that will not clean out your wallet. The shop that I contacted in san antonio about installing a cam in an 05 gave me quote of 40 hrs and said he had never done one and would most likely have to pull the motor..
I have used the guy before but 40 hours seems a little on the extreme side of time and I think his rate is 70 per hour which equals out 2800. I am also going to install a new turbo and exhaust manifold. THis kind of cost makes it an no way situation.
I am not so much have a problem with rate but the time quoted when I read other posts that it takes 8 to 12 hours.
If there is somebody else in any area of texas I am more than thankfull for any information.
thanks
Old Jun 10, 2006 | 11:33 AM
Don M's Avatar
DTR Advertiser
thanks
The factory service manual calls for 40 hours. A little over the top IMO. Chris @ Relentless Diesel is in the Houston area. Just North of Houston I believe. Willis area. He has done tons of cams and you dont have to pull the engine.
Some shops raise the engine up some, but you dont have to pull it. Some modify a thin sheet metal cross member. Either way is no big deal. It is more like 8 hours.
Don~
Old Jun 10, 2006 | 11:50 AM
Thanks for the info Don M. I had decided on your helix two cam with springs and was just doing my homework before I bought and ended up with having to do it myself.
I will contact them at Relentless diesel.
Old Jun 10, 2006 | 12:10 PM
BigBlue's Avatar
I highly recommend chris. I've known a lot of people that have had work done their and he's going to be doing my tranny install for me. He's a great guy and does awesome work.
Old Jun 10, 2006 | 02:29 PM
Tom's Avatar
Tom
Check with Diesel Innovations in Houston. They do good work.
www.dieselinnovations.com
Old Jun 10, 2006 | 02:53 PM
Tmc243's Avatar
Labor Operation Detail
Select LOP Description Failure Codes Material Allowance (USD) Type Hours
09050116 Camshaft - Replace Cummins Diesel (A) Primary 5.3 hrs.
Unfortunitly Chrysler has figured out you don't have to pull the engine . This is a copy out of the current warranty manual. Normally you will pay 1.5 to 2.0 times the warranty time for "retail". I'll put in another vote for Chris @ Relentless Diesel.
Old Jun 10, 2006 | 04:56 PM
PourinDiesel's Avatar
When my first cam was installed I had a friend who is local do it. Him and another guy did the install in about 10 hours.
By myself I could probably knock just a cam out in about 12 hours or so.
I have never done "just" a cam so I couldnt say accurate I guess.
Old Jun 10, 2006 | 05:06 PM
essgeetee's Avatar
Chris @ relentless for sure... Get him to do your CP3 at the same time!
Old Jun 10, 2006 | 08:42 PM
cliffs03hd's Avatar
I am in san antonio and installing a cam and springs in my truck right now. If you want I can help you do it. My number is 210-559-8497. If you need any assistance let me know . Cliff
Old Jun 12, 2006 | 06:31 AM
cliffs03hd's Avatar
Truck Source Diesel
4041 rittiman rd. suite 101
San Antonio, TX
210-654-6767
I work there Cliff
Old Jun 12, 2006 | 12:08 PM
TX_Diesel's Avatar
PowerDually,
I know a guy in Natalia, (20 mins south of SA off I35). If you havn't got someone to do it yet. He was a cummins mech for chysler for about 10 years there in SA. email me if you want his info. Vortec2@aol.com
Old Jun 12, 2006 | 12:36 PM
gunracer1's Avatar
i will give a vote for relentless diesel. i have timed more than a few trucks and the only one i had ever got hold of that was supposed to be timed, that was dead on, was a truck from relentless.
Old Jun 12, 2006 | 07:36 PM
Argo's Avatar
www.trucksourcediesel.com
it is on rittiman and I-35 in SA. Great bunch of guys.
Old Jun 13, 2006 | 10:18 PM
cliffs03hd's Avatar
If you have any quams about doing these upgrades..... Don't the are so worth every penny of it. If you want call me at teh shop tommorow or on my cell I can tell you more. All I can say first impressions are Great. Cliff
Old Jun 16, 2006 | 08:48 AM
Argo's Avatar
Had Chris put on an AEM brute force air filter/cold air intake. Went in my wifes mustang. Very prompt service and great bunch of guys over there.
