P0628 code with fass and arson?
Old Dec 20, 2011 | 10:59 AM
southpawslingr1's Avatar
I just installed the majority of the upgrades listed in my sig. The fass however has been on there for some time. Never had this code until I installed the rest of the items. I am having a intermittent problem with the truck falling on its face for like 3 seconds then clearing up. It has done it twice in two days. I know my fass is working becuase it's one of the old loud ones and I can hear it pumping away.
Old Dec 21, 2011 | 09:10 AM
no_6_oh_no's Avatar
P0628 Low Voltage Detected At The Fuel Lift Pump Relay
Check your wiring to make sure something is not loose. Maybe it got bumped or not set correctly with the install.
The other problem could be the FCA. Try your stock one and see if it changes.
Old Dec 21, 2011 | 11:08 AM
OK tried my stock FCA its not that it popped the code again after I cleared it. I also have P1246 now which is Fuel injector group A supply voltage circuit open. This is starting to get frustrating!
Old Dec 22, 2011 | 12:14 PM
Diagnosed the problem after chasing ghosts for two days. Injector wire was touching a rocker arm. Since we fixed it and cleared codes no issues.
Old Jan 17, 2012 | 03:55 PM
timwhattadude's Avatar
Getting the same codes P0628 and also P0148
recently my Dodge ram 3500 began to stagger while driving at about 40-50mph, but when going faster it stops. Then it started cutting out every 10 minutes while driving till it just wouldn't start. Code showed P0148. I Changed my lift pump (fuel transfer pump) and the truck began to drive again. Its been about a week and now the staggering is back and a little worse and i'm showing codes P0148 and now a new one P0628. Any ideas on what to do or how to fix this? the staggering seems to be getting worse.
Raspy
Dec 22, 2016 06:34 PM
stackediesel
Apr 27, 2009 02:35 PM
Stainless
Aug 20, 2008 09:23 PM
DirtEater
21
Feb 6, 2007 06:26 PM
973604x4
Jun 14, 2006 11:11 PM
