opps
Old Mar 23, 2004 | 05:03 PM
jt's Avatar
jt
opps
I removed the black straight piece between the turbo and the filter. Not sure which way it goes back in. When I removed it I noticed arrows, then later I notced arrows pointing in each direction. Help.
James
Old Mar 23, 2004 | 07:05 PM
Tfeore's Avatar
On mine, you can read the part number from left to right or top to bottom as this case may be.
Tom
Old Mar 25, 2004 | 05:00 PM
natstayl's Avatar
Same here. Read from the top to bottom.
Old Mar 25, 2004 | 05:21 PM
Jannetty Racing's Avatar
It doesn't matter it can go either way, it is just a muffler.
HMM, imagine that a muffler in the intake, what a concept
Old Mar 25, 2004 | 08:53 PM
jt's Avatar
jt
On another thread it was stated that with the intake "muffler X screen" removed the mileage dropped. The ribs on the inside of the pipe have spaces between them that are not even.
James
Old Mar 25, 2004 | 09:23 PM
blownaway's Avatar
I am very curious how removing it will effect things,I will leave the ring in but wouldn't mind getting rid of the baffle. I have heard conflicting stories ????
Old Mar 26, 2004 | 12:01 PM
JKE's Avatar
JKE
I would not recommend removing the X unless you are removing the entire pipe and replacing with a smooth bore pipe. The ribbs inside the original make for some poor flow. I can tell my throttle response and the "feel" went down on mine. I don't like it really. I'll get around to replacing the pipe sometime. Sounds good though. JKE
dieselfreak21
Jan 14, 2011 03:02 PM
BC847
Apr 27, 2010 09:09 PM
klx650a2
Nov 5, 2007 08:50 PM
TX_Diesel
Jul 17, 2007 09:13 PM
abc4yew
21
Oct 15, 2006 09:14 PM
